11-06-2016, 07:47 AM | #1 |
Newbie Join Date: Oct 2016 Location: norfolk Virginia
| Yeti on asphault
It seems every time I run my yeti on road I break something... I can beat the snot out of it at the construction yard but on asphault something breaks I'm dropping in a savox sc0251mg to replace my stock servo what servo saver should I use (currently using the vanquish steering setup sans saver) Sent from my SM-G920T using Tapatalk |
11-06-2016, 08:18 AM | #2 |
Pebble Pounder Join Date: Dec 2015 Location: Portugal
| Re: Yeti on asphault
No center diff and a locked rear diff, makes it harder on the mechanical components... Look at Hot Racing steering with adjustable servo saver, would be my choice had my Yeti not already come with another setup (bought 2nd hand) Sent from my SM-G900F using Tapatalk |
11-06-2016, 08:20 AM | #3 |
I've got all vanquish stuff ... is there one that mounts to the Servo that will work Sent from my SM-G920T using Tapatalk |
11-06-2016, 09:35 AM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
in one of the threads here someone used one on servo side. but i don't remember who. (i'm getting old ) As steering servo for a yeti the 0231 is a little weak with 12kg in my eyes. wouldn't go under 20kg personally (more is better). A higher torque servo maybe could also help you out but not sure. In general driving on asphalt will higher the risk of breakage, cause asphalt doesn't give. All force goes into the rig. |
11-06-2016, 09:37 AM | #5 |
Newbie Join Date: Oct 2016 Location: Grain Valley
Sounds like to me its an issue of to much grip or traction
11-06-2016, 10:12 AM | #6 |
I'm well aware of how assfault can destroy an off road rig (learned that with my built Baja 5t) but I was just testing her after programming my esc... side note I think ima drop in my cc 2650kv and max 8 esc what gearing should I use for 3 sometimes 4s? Sent from my SM-G920T using Tapatalk |
11-06-2016, 12:02 PM | #7 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
Im running the UD ratios f/r. Slightly more surface area for better tooth engagement besides the obvious extra reduction. If youre gonna be spending any extended amount of time on pavement, Id suggest some shorter tires to bring the CG down a bit and definitely get that rear locker outta there. It's putting massive strain on the rear axles, gears and driveshaft. And I have to agree with magic_yeti on the servo. I have an 0231 in my scx10 and it gets the job done. But its really just a slight bump in power campared to the rtr servos. Not bad, but not enough for a fast 2.2 truck IMO. My yeti uses a Tower Pro mg968. Last edited by DeviledEggs; 11-06-2016 at 12:13 PM. |
11-07-2016, 08:44 AM | #8 | |
Rock Stacker Join Date: May 2015 Location: central PA
| Re: Yeti on asphault Quote:
If I want to go faster, I'll grab another RC to get my thrills. Going over rough terrain at moderate speeds is what the Yeti was designed for. A Yeti doing on-road duty is just not right in my book . | |
11-09-2016, 04:43 AM | #9 |
I think I'ma keep the stock motor till she burnes up im leaning tword a tenshock sc401 3500 kv... anyone have anyone have anyone have any experience with these motors but I've got an sc8 esc otw .... just picked up a hitec hs 7950th servo would it be safe to not use a servo saver on this beast Sent from my SM-G920T using Tapatalk Last edited by acidtherory420; 11-09-2016 at 04:46 AM. |
11-15-2016, 06:17 AM | #10 |
I'm running a tekin 30004x4 geared at 12/64 with rear ud. As I am running the tall super Swampers I've decided no servo saver, with my 7954, so far so good. I've geared this down and with the two speed I can go thru walls or over them. Biggest issue I had was eating dog bones, Eric solved that Hang up and Drive |
11-16-2016, 10:52 AM | #11 |
I found a solution with servo side servosaver from GPM. Maybe that's what you're looking for. AXIAL RACING YETI SPRING STEEL ANTI-THREAD TIE ROD WITH ALUMINIUM HI-TORQUE SERVO SAVER 25T- 1SET - GPM YT16025STM |
11-16-2016, 11:53 AM | #12 | |
Got that, useless with a strong servo. my Hitech overpowered it.every rotation, center was different Hang up and Drive | |
11-20-2016, 02:44 PM | #13 |
Rock Stacker Join Date: Nov 2016 Location: somewhere very rocky
Just don't hit the curb only thing I ever broke on asphalt is plastic spur gear
Yeti on asphault - Similar Threads | ||||
Life of one YETI - Tom Frajer's Axial Yeti build log | TomFrajer | Axial Yeti | 320 | 05-22-2017 09:01 PM |
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
