02-04-2017, 06:51 AM | #1 |
Newbie Join Date: Dec 2016 Location: West tn
| Ssd rear axle question
Hey guys fixing to buy a new ssd rear axle for the yeti , but im having trouble making up my mind if I want the wide or the stock width. I'd appreciate hearing yalls opinions suggestions and what y'all ended up putting on your rigs
02-04-2017, 07:01 AM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Ssd rear axle question
Wide. sent by magic_yeti |
02-04-2017, 07:03 AM | #3 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
I went with the wide.
02-04-2017, 07:09 AM | #4 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
In my extremely limited time driving my Yeti I'm glad I bought the wide. As easily as it flips over while turning on high traction surfaces, it needs all the width it can get.
02-04-2017, 07:10 AM | #5 |
Can I ask what made you guys pick the wide over the other ?
02-04-2017, 09:53 AM | #6 |
u can use same hub size front rear. narrow the hub size in the rear -> less stress an the axle on yeti rolls. option to use still wider hub in the rear to gain wider track (my setup right now 22mm rear 14mm front) for better stability on gras. |
02-04-2017, 01:09 PM | #7 |
Makes since . thanks guys
03-06-2017, 06:04 PM | #8 |
I debated and went with the stock width. The centered pumpkin works well, and as I'm not speeding with it and the extra width would make me use wider front hubs.... Just me. Hang up and Drive Last edited by mikemcE; 03-06-2017 at 06:07 PM. |
03-08-2017, 01:52 PM | #9 |
Newbie Join Date: Feb 2017 Location: Seattle, WA
If you do the wide in the rear, should it be done up front as well?
03-08-2017, 02:00 PM | #10 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Just don't use offset on your wheels that push the wheel outboard (negative offset) or you'll end up with a collection of bent axle shafts. Just my 2 cents worth, Bob |
03-08-2017, 03:30 PM | #11 |
| Re: Ssd rear axle question |
03-08-2017, 03:36 PM | #12 |
So far no issues even in rolls that breaks SSD HD rods in the trailing arm. But I mentioned that possible my pin mounted hubs are the differenz to the others who have bend axle issues. Still new to this just a thought. sent by magic_yeti |
03-09-2017, 08:51 PM | #13 |
Ssd rear axle question - Similar Threads | ||||
SSD Rear Axle | Hunter711 | Axial Yeti | 152 | 09-09-2019 12:56 PM |
Using SSD Diamond front Axle as rear | rngrchad | 2.2 Scale Rigs | 7 | 07-16-2019 10:06 PM |
New SSD Rear Axle Shafts for D60 Wide Axle (XR) | SSD | Axial SCX-10 | 0 | 05-17-2016 10:51 AM |
