Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: need steering knuckle and carrier set
Old 02-22-2017, 02:18 PM   #1
Default need steering knuckle and carrier set
I broke my front steering knuckle/carrier. what are my upgrade choices? I looked at some nice vanquish ones but just wondering what other brands are good
Donny939 is offline   Reply With Quote
Old 02-22-2017, 02:44 PM   #2
Default Re: need steering knuckle and carrier set
i went with vanquish c-hubs and knuckles fit great and looking nice
so far no issues. I think that's the mainly used option.
But there are several options from ssd, gpm, i think boomracing aso
i have a few gpm upgrades on my little monster and they also fit nice and looking great also no issues. But the material feels a little less strong than the vanquish.
so on parts that are under stress i would prefer vanquish or ssd.
magic_yeti is offline   Reply With Quote
Old 02-22-2017, 05:37 PM   #3
33m
I read on here that the Vanquish knuckles rub on the kit stock wheels. I haven't actually seen a picture of how much,
but I have some Vanquish knuckles that should be here on Friday, and I ordered the Vanquish .450 SLW hubs just in case.
33m is offline   Reply With Quote
Old 02-22-2017, 06:40 PM   #4
thanks for the replies. ill probably end up getting the vanquish. how did you know to order the .450 slw hubs? can you lemme no if the stock rub
Old 02-22-2017, 08:06 PM   #5
33m
oops, I should of written .475. I've heard the .350 will clear too. But I will post pictures up when I get my knuckles.
With the plastic axial spacers and the Vanquish ones.
Old 02-23-2017, 05:10 AM   #6
thanks
Old 02-24-2017, 11:55 AM   #7
I ended up going with hot racing knuckles and caster block.. I kinda watched the vanquish but my hobby shop doesn't carry them. so if anyone cares ill let ya know how they fit/work out. part # yet2101 and yet19x01. also ordered hot racings motor mount... guess its gunna be a hot racing yeti. I already have the hot racing steering set up and that seems to be working good with no issues
Old 02-24-2017, 02:19 PM   #8
33m
If anyone is going to go with Vanquish knuckles, you can order Gearheads GEA1240 SLW Hub Spacer Kit with 4-40 Screws,
Gear Head RC SLW Hub Spacer Kit with 4-40 Screws (4)
and the spacers plus the stock hubs will allow the kit stock wheels to clear the Vanquish knuckle.
I only bought the spacer kit because it had 24 4-40 screws which I needed because I also ordered,
Vanquish SLW hubs. Vanquish was out of 4-40 screws when I placed my order.
Also get screws that are 3mm longer if you want to stay metric, otherwise you'll have to widen the holes a little
on the kit stock rims to allow the 4-40 screws to pass through.
https://www.amazon.com/Steel-Alloy-K.../dp/B00O9Y5A58
Even better, 14mm long screws.
https://www.amazon.com/Steel-Alloy-K...w+Bolt+M2.5x14
Old 02-24-2017, 07:08 PM   #9
33m
Installed Vanquish C hubs and knuckles. It just barely rubs the rim sometimes with the stock Yeti kit hub.
I'm not going to put the Vanquish hubs on for now.
Also the Vanquish steering rack rubs ever so slightly under where the driveshaft enters the front differential.
I read about it happening and was looking for it, seemed kinda bad. But then I installed the front end and the
wheels/tires and you can't even tell. I squirted some silicon lube onto where it hits just in case.
Old 02-24-2017, 08:12 PM   #10
looks good 33m. ill post pix of my hot racing knuckle/caster block when I get mine installed..nm can't post pix but ill let ya know if it rubs
Old 02-26-2017, 06:23 PM   #11
no rubbing.. works good. going to be a pain to remove the big bearing though. I wanted to use a new one but I didn't have any that size so I used the axial original
Old 02-26-2017, 10:31 PM   #12
33m
My big bearing dropped out of my stock knuckle, the other one I just tapped against the floor and it fell out.
Now getting the bearings into the Vanquish knuckles took a little work.
Putting all the bearings in the freezer, I was able to drop in both small ones and one big bearing.
In one of the knuckles the big bearing wasn't going in easily,
so I heated the knuckle up to around 120F over the fireplace and then pulled the big bearing out of the freezer,
and it slid in. I also used a tiny bit of silicon lube on the knuckles to help the bearings slide in.
I sprayed some on a bag and just used my fingertip to wipe the bearing areas.
need steering knuckle and carrier set - Similar Threads
Steering knuckle carrier options? npcaldwell Axial Yeti 7 10-10-2014 09:31 PM
Steering knuckle? asian195 Axial XR10 8 11-10-2011 07:23 AM
Steering Knuckle Help! lilengine44 Redcat Crawlers 13 02-06-2011 03:32 PM
inside tyre touches steering knuckle / steering linkage murky123 Axial SCX-10 4 10-06-2010 04:46 PM
