06-02-2018, 09:59 PM | #1 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| More steering?
Spent the day building my yeti. Full optioned build, VP rack/arms, bearings, turnbuckles, etc. Accpetable amount of slop... Before I just attack it with the dremal, are there any threads or mods for getting more steering? There looks to be a few spots that could be modded, but I haven't seen anyone post about mods to get more, just fixing what's there. |
06-03-2018, 12:26 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: More steering?
I've not seen a definitive thread on steering mods. You may tweak a bit more by removing some material from the diff case, but for me the 2.8 wheels I use already hit the suspension at full lock. A bit of toe in will counter the ackermann geometry to give a bit more turn in on the outside wheel. Following that, consider rear steering. An easy bolt-on, but requires a rear servo that is as good or better than what you have on the front. |
06-03-2018, 02:32 PM | #3 |
| Re: More steering?
Spent some time modifying things today. With the janky design you need a 400oz+ servo because it needs a longer servo horn to get the throw required. Too big of a servo will hit the rack and limit steering too. Aluminum caster blocks would be a good investment too... I'm not sure if the plastic will hold up or not. Rack hits the chassis. Where it starts to raise up Caster blocks limit knuckles, a lot Rack rubs the under side of the bulkhead by the driveshaft, just a little Rod ends hit the bulkhead. Rack can hit the servo ear of the servo depending on size. My normal sized servo rubbed just a bit. Stock Not stock |
06-14-2018, 11:28 PM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: More steering?
Did you measure before and after steering degree angles? This is something I've been meaning to tackle.
06-16-2018, 04:40 AM | #5 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
| Re: More steering?
Factory steering linkage from the servo is too short. That's why it likes to pull the rod ends off too.
06-16-2018, 12:51 PM | #6 |
| Re: More steering? |
More steering? - Similar Threads | ||||
Steering/Alignment Problem After Install RPM Steering Knuckles? | Barzan724 | Newbie General | 2 | 01-21-2016 06:32 PM |
Idea for scaler steering... Need ideas for building a steering box. | JavelinSST390 | General Scale Talk | 25 | 05-14-2015 02:32 PM |
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
