Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: SSD wide diamond rear axle
Old 06-28-2018, 10:54 AM   #1
Default SSD wide diamond rear axle
I put one of these in my recently purchased used Yeti Score TT and had problems with tight ring and pinion mesh. I ended up making a paper gasket to shim the carrier housing out whick worked fine. I thought of replacing this gasket with a small o-ring. I've looked for directions online on assembling this axle but have not found anything conclusive as to what i might have done wrong. I have to check but i don't know yet if the gears are stock or aftermarket. It seemed like they had a spiral cut to them which makes me think they're not stock. Anyway does anyone have any ideas what might be wrong? Sorry if i posted this in the wrong area but i don't see a specific S.T.T. section.
Sent from my VS996 using Tapatalk
dgechrgr469 is offline   Reply With Quote
SSD wide diamond rear axle - Similar Threads
Using SSD Diamond front Axle as rear rngrchad 2.2 Scale Rigs 7 07-16-2019 10:06 PM
SSD Diamond wide axle and spool question. magic_yeti Axial Yeti 2 11-03-2016 05:22 AM
SSD wide diamond axle install instructions? oosel Axial Yeti 4 11-05-2015 06:42 PM
