Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: open rear diff?
Old 10-08-2018, 08:24 AM   #1
Default open rear diff?
I want to open the rear diff on my Yeti for track racing. Unfortunately you cannot just put another front open diff in the rear because it requires c clips on the output shafts. Does anyone know how I can open the rear diff on the Yeti?
Thanks!
Stan3535 is offline   Reply With Quote
Old 10-08-2018, 08:36 AM   #2
Default Re: open rear diff?
Thanks!
Get an SMT diff off of fleaBay and it’ll drop right in.
Brake Weight is offline   Reply With Quote
Old 10-10-2018, 08:21 AM   #3
thanks!
Old 10-11-2018, 04:50 AM   #4
Thanks!
The rear doesn’t need c clips. I have open diff on the front of my wraith.
I just brought the diff gears and bodged a pin out of an old shock rod.
Come to think of it I don’t remember seeing any c clips inside the plastic that bolts on to the crown gear
Rubber tutti is offline   Reply With Quote
Old 10-30-2018, 06:12 AM   #5
Does this mean you cannot fill the diff with oil? You just need to grease it?
MrWinterkorn is offline   Reply With Quote
Old 10-30-2018, 07:21 AM   #6
I never tried to put diff oil in it. I did pack it with some thick grease I had handy.
Old 10-30-2018, 09:35 AM   #7
If you use.diff fluid.you will need a gasket too and some orings to keep the fluid in theres some tricks to getting the fluid.levals right but not a big deal
ferp420 is offline   Reply With Quote
open rear diff? - Similar Threads
Open rear diff??? Tgreer Vaterra Twin Hammers 13 06-23-2020 05:57 PM
Open Rear Diff nedmo Axial SCX10 II 4 08-09-2017 04:50 PM
Front Diff to use as Rear Open Diff ongbenghui Vaterra Twin Hammers 5 03-02-2017 12:54 PM
Open rear diff Lochrie2 Vaterra Twin Hammers 3 02-11-2016 08:26 PM
Open rear diff? Stan3535 Vaterra Twin Hammers 26 12-16-2015 11:35 AM
