10-22-2019, 10:47 AM | #1 |
Newbie Join Date: Feb 2016 Location: Poland
| Vanquish motor mount and gear "shielding"
hi, so i finally had time to dismount, clean and mount motor and transmission onto my Vanquish motor mount. All went well until i had to attach spur gear. As it turned out slipper plate (31067) is touching one of the gear "shielding" (31107). I dismounted everything and tried to apply more pressure when attaching gearbox and it helped a bit but problem is still there - spur gear is not moving freely when everything is disconnected ... Anyone had this issue or knows how to handle this? is it problem with factory screws, do i have to trim something or just skip shielding and drive without it? How will gearbox and engine deal with sand and water? Thanks! |
11-21-2019, 10:10 AM | #2 |
Newbie Join Date: Apr 2019 Location: Plano
| Re: Vanquish motor mount and gear "shielding"
Is everything here stock with the exception of the Vanquish motor mount?
11-22-2019, 11:34 PM | #3 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
Make sure that the motor mount is pushed all the way into the gearbox. It's a tight fit. I had the same problem, and realised it was just because the mount wasn't screwed tight enough.
11-25-2019, 09:38 AM | #4 |
Rock Stacker Join Date: Aug 2019 Location: Arlington
The vanquish plate fitment is tighter than the stock. It can take a good bit of work to get it to sit properly flush. I had the exact problem you describe and it was due to the fact that the plate *left* tight, but was still a couple mm out from flush. Trick I used to make life easier was to remove it, get a little lube on a q-tip (I just used some 40 wt shock oil really) and dab it in each hole that mates to the case. That allowed it to slide into place more easily. Also, when you tighten the bolts, do them a little bit each, working in an X pattern to keep the plate as squared to the case as possible. If you do one a whole bunch, it can angle the plate and just make life harder. |
11-27-2019, 10:30 PM | #5 |
Rock Crawler Join Date: Apr 2017 Location: US
I had to use a dremel on the mounting holes because they were to tight on mine. Fits great now. Just a bit disappointing coming from vanguish.
Vanquish motor mount and gear "shielding" - Similar Threads | ||||
"Yeti Edition" LED light bar and mount combo kits from Gear Head | Gear Head RC | Vendors Electronics | 2 | 09-29-2014 10:21 AM |
RCP Crawlers "Everyday Low Prices" Hitec 645 Metal Gear Servo "GIVE-A-WAY" | Rockpiledriver | RCP Crawlers | 126 | 01-03-2007 10:36 PM |
