11-17-2019, 09:55 AM | #1 |
Rock Stacker Join Date: Nov 2019 Location: uk
| Stock tyre question
Git a Yeti kit and really surprised how soft the tyres are, even with the supplied foam fitted. I am just going to run on "flat" terrain no rocks to grip for me. Should I leave the tyres as they came until I need to change them? Or are they not upto spirited use and change right away? |
11-17-2019, 10:00 AM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Stock tyre question
You will need different Foams, best are the crawler Innovations Duece Wild Standard or the New hd version depending on weight Gesendet von meinem Pixel 2 XL mit Tapatalk |
11-28-2019, 12:07 PM | #3 |
Rock Stacker Join Date: Aug 2019 Location: Arlington
Yes, the stock foams are too soft and basically junk. The tires aren't terrible, but the foams kind of ruin them. Just today I fit up a set of Pro-Line Flat Iron XL, and a set of Crawler Innovations, CWR-3003 Deuce's Wild foams... Obviously the tire change doesn't allow a 100% apples to apples comparison, but the difference is huge in a positive manner. Even though the XLs are a little bit taller than the stockers, with the Deuces Wild foams the handling was more crisp, the tendency to lift a wheel during a powered turn was down and was the tendency to roll over (with no suspension changes) The key difference is that the harder/stiffer foam of the Deuces prevents the sidewall from deforming or even folding over under lateral loads like the stock foams. If you want to re-foam the stock tires, you might try the CWR-3014, they are a little smaller OD than the 3003. |
Stock tyre question - Similar Threads | ||||
another tyre question.. :P | amatris1996 | Axial SCX-10 | 5 | 11-25-2015 03:13 PM |
What tyre could be used besides the stock tyre? | lotaloi | Losi Micro-Rock Crawler | 2 | 03-31-2010 06:22 PM |
what tyre to use | munky | Tires and Wheels | 16 | 09-28-2009 06:23 AM |
Noob tyre question. Vented or not? | Zanx | Newbie General | 4 | 03-20-2009 02:10 PM |
What 1.9 Tyre to get? | Kanzai | Tires and Wheels | 2 | 12-01-2007 01:39 PM |
