Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: RC4WD: XVD for RockForce and Berg
Old 02-24-2009, 12:06 AM   #1
support@rc4wd.com
roborg5000's Avatar
Default RC4WD: XVD for RockForce and Berg
RC4WD will soon release Hardened Steel XVDs for the Rock Force and Berg
Stay tuned here for more info or check the storefront often
roborg5000 is offline   Reply With Quote
Old 02-24-2009, 08:37 AM   #2
binaryterror's Avatar
Now don't take this as harsh...I'm trying to be nice here. But watching my pocket book as well as durability in my truck. Remember the stock Dogbones do work very well.
But will they be actually Alpha and Beta tested before being released only to fail and leaving us waiting for another change?
binaryterror is offline   Reply With Quote
Old 02-24-2009, 09:05 AM   #3
support@rc4wd.com
roborg5000's Avatar
I understand that for sure and the axial stub shafts are a cheap replacement.
I think getting a greater turn radius is the point to these.
I have a RockForce on the way for testing these and other parts coming for the RockForce.
As always i promise to give an honest opinion ;)
Old 02-24-2009, 05:45 PM   #4
XJ Farmer's Avatar
Good luck and if they hold up to some good falls you will sell a piss load of sales. See ya soon
Later
Farmer
XJ Farmer is offline   Reply With Quote
Old 02-24-2009, 06:45 PM   #5
Can you make some for the HR axles too please.
renoirbud is offline   Reply With Quote
Old 02-24-2009, 08:10 PM   #6
Pure Pwnage
dave56bug's Avatar
Nice, I am liking the looks of those RockForce CVD's
dave56bug is offline   Reply With Quote
Old 02-25-2009, 04:11 AM   #7
Have you guys given any thought to running the solid shaft all the way out to the end of the stub at say 6-8mm diameter. Then where you would normally have the threaded stub with a wheel nut instead you would have an internal thread with 3-4mm hardware to secure the rim.
This gets rid of the weaker threaded end of the stub which is prone to bending or snapping.
I was running custom made versions of this design on my Clod and never broke one.
Just a thought
Can I get a set when you pick up my idea :-)
Shorty40 is offline   Reply With Quote
Old 02-25-2009, 06:52 AM   #8
Then wheel mount depth will become an issue. Some are thicker than others, even in RC4WD's line there are variances.
Old 02-25-2009, 07:01 AM   #9
support@rc4wd.com
roborg5000's Avatar
Originally Posted by XJ Farmer View Post
See ya soon
Later
Farmer
Is that a threat
Old 03-07-2009, 03:24 AM   #10
what about the cross pin that holds it together. All the cvd's i have broke have been the pin. for not being big enough. If the pin is the same size as the Mip's and Axial's then there not strong enough.The stress we put on them in dig makes it the weakest link, and will fail first all the time.
Flyin Hawaiian is offline   Reply With Quote
Old 03-07-2009, 09:48 PM   #11
Really?
montana.matt's Avatar
Originally Posted by renoirbud View Post
can you make some for the hr axles too please.
x2.....
montana.matt is offline   Reply With Quote
You may edit your posts
