Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Bomber RR10 parts
Old 12-11-2015, 08:47 AM   #1
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Bomber RR10 parts
Dlux and UCfab are happy to announce the start of our Axial Bomber RR10 line of parts!
I will continue to add all the parts that I carry in this first post so keep checking back.
Dlux Ultra 4 G10 truss
https://dluxfab.ecwid.com/#!/AR60-Wr...unt/p/29404646
Aluminum sway bars from UCfab.
  • Made from 6061 aluminum
  • Ability to run 3 different thickness torsion bars for a softer or more firm feel
  • Ability to run from the rear bumper or mid chassis (need to choose the proper torsion bar.)
https://dluxfab.ecwid.com/#!/Bomber-...FAB/p/57744457
Dlux carbon fiber sway bar
Will work in the rear bumper, rear mid chassis and front chassis.
Comes with un cut torsion bar and un cut end links so you can make them any size you need.
https://dluxfab.ecwid.com/#!/Sway-Ba...sal/p/32734246
UCfab trailing arms.
  • Made from 7075 aluminum for maximum strength and hardness (easy to slide on rocks)
  • Uses the common, reliable and replaceable Revo rod ends
https://dluxfab.ecwid.com/#!/Bomber-...fab/p/57554500
Full set of Titanium links from Dlux fab.
  • Rear uppers come in stock lengths or Dlux truss/VP Currie truss lengths (no more need for the weak Jato ends)
  • Front lowers are a single bend for clearance 1/4" TI for ultimate strength
  • Uppers, steering and drag link are all 3/16" TI
https://dluxfab.ecwid.com/#!/Bomber-...nks/p/56237898
UCfab front sway bar mounts
Allows you to mount a sway bar in the front
Use the Dlux universal sway bar kit or Axial wraith sway bar
https://dluxfab.ecwid.com/#!/Bomber-...fab/p/57899058
Modified big bearing housings
Takes the 11mm bearing and turns it into a 13mm bearing on the inside. No more blown bearings or blown ring and pinions.
https://dluxfab.ecwid.com/#!/Modifie...ngs/p/32422412
No slop bushings for the knuckles/chubs
Take all the slop out of your steering setup with these.
https://dluxfab.ecwid.com/#!/XR10-Wr...ngs/p/13884383
I also have great deals on replacement shafts and bevel gear sets. Axle shafts can be bought with the 70* steering mod for more/bind free steering
https://dluxfab.ecwid.com/#!/Wraith-...fts/p/24859916
https://dluxfab.ecwid.com/#!/Axial-H...ars/p/49417324
Holmes lockers
https://dluxfab.ecwid.com/#!/Locker-...mes/p/47996043
Hitec HS 7950 servos
https://dluxfab.ecwid.com/#!/Hitec-HS-7950/p/50779342
Vanquish C hubs and knuckles
https://dluxfab.ecwid.com/#!/VP-Chub...cts/p/22741848
https://dluxfab.ecwid.com/#!/VP-Knuc...cts/p/22741849
Dlux 1808 axles
https://dluxfab.ecwid.com/#!/1808-ax...egory=12405705
Erik D_lux is offline   Reply With Quote
Old 12-11-2015, 12:03 PM   #2
Default Re: Bomber RR10 parts
Merry Christmas to me!
generalee7 is offline   Reply With Quote
Old 12-14-2015, 06:52 AM   #3
Erik D_lux's Avatar
Thanks for the orders guys!
I forgot the Ultra 4 trusses so I put those in the first post.
Old 12-16-2015, 07:17 AM   #4
Erik D_lux's Avatar
Guess I forgot more than I thought!
Added:
Holmes lockers
Hitec 7950 servos
Vanquish C hubs
Vanquish knuckles
Dlux 1808 axles
Bomber RR10 parts - Similar Threads
bilinvic's RR10 Bomber Build bilinvic Axial RR10 Bomber 712 04-25-2020 08:09 AM
Rr10 bomber available from tower jaykim5708 Axial RR10 Bomber 12 05-05-2016 07:28 PM
No Axial RR10 Bomber section? ROLANDROCKSHOP Comments, Suggestions, and Help 8 12-26-2015 04:06 PM
You may edit your posts
