06-11-2012, 12:45 PM | #1 |
| Delrin Bully tubes
I am going to make Delrin Bully tubes for both the 2.2 and super. These tubes will be just like my Berg tubes, they will use the same style shock mounts and AX10 C hubs. There is a lot of grinding to do on the Bully knuckle to get full throw out of them. I also sell the knuckle that is pre machined. 2.2 version $135 Included is 2 rear tubes, 2 front tubes and 4 shock mounts. I can make these tubes so they are a direct replacement, make them like Stubs and do Berg width or I can do anything in between if you give me a measurement. If you do wider than stock, you will need wider than stock axle shafts. The super Bully shafts work good for this. These tubes do not use an inner bearing on the tube. Super version $150 Included is 2 rear tubes, 2 front tubes and 4 shock mounts. I have never made a set for the supers so these would be considered prototypes right now. Since the Berg super tubes have held up to some serious abuse, I expect these to be just fine but, buyer beware, no warranty on these. If you expect your car to be really heavy even after installing these tubes, they may not be for you. These tubes do not use an inner bearing on the tube. Milled out knuckles: $60 for machined style knuckles, $50 for cast style knuckles or $35 if you supply the knuckles. This includes 4 - 8 x 12 axle bearings and 4- 3 x 6mm kingpin bearings for no slop Bully style knuckle weights: $60 for just the main weight. Last edited by Erik D_lux; 06-11-2012 at 01:11 PM. |
06-11-2012, 12:49 PM | #2 |
| Re: Delrin Bully tubes
Availability: Right now I am doing a pre order. At this time I do NOT plan on stocking these tubes so if you want them, the time is now, or you can wait until I do another batch (month or more away). No tubes are currently made. I expect to have them done in the next 3 weeks. That is just a guess so please dont hold me to it. They will be done as soon as possible and I work fast. Please understand that I will not put these off and make anybody wait but I already have a heavy work load so I will only be able to work on them when time permits. Please PM me with your paypal email and I will send a paypal request for what you want. I plan to start working on these this week if things go well. Thanks! |
06-11-2012, 12:49 PM | #3 |
Save another
06-11-2012, 12:50 PM | #4 |
One more in case I forgot anything.
06-11-2012, 06:14 PM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
You forgot delrin gear case...... |
06-11-2012, 11:10 PM | #6 |
I wish. LOL. I need one for my Berg first.
06-12-2012, 03:25 AM | #7 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Looking good Erik... |
06-12-2012, 05:24 PM | #8 |
Pebble Pounder Join Date: Jan 2010 Location: League City
How much do the bully knuckle weights weigh?
06-13-2012, 01:02 AM | #9 |
3.1oz on my scale
Delrin Bully tubes - Similar Threads | ||||
<<< Delrin Rear Bully Tubes >>> | Chaotic Crawlers | Axles, Trannys, T-case | 177 | 04-27-2012 06:54 PM |
~Delrin Rear Bully Tubes~ | 53 willys | RC4WD Bully | 81 | 09-28-2010 01:14 PM |
