03-18-2015, 03:13 PM | #1 |
| Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates They're Here! Krazed Builds brings you Carbon Fiber gear plates for your XR10. For those looking to shed some weight, those looking for a Vp alternative or those looking for a little bling .... These are them. All plates take the Bigger bearings like a Vanquish plate for that added extra toughness. They fit right in to a Stock case, RC4wd case and the Vanquish case .... no modifications needed. You will need: (2) 5x10x4 flanged bearings 5x10x4 (FLANGED) Rubber Sealed Bearing MF105-RS (1) 5x9x3 flanged bearing 5x10x4 (FLANGED) Rubber Sealed Bearing MF105-RS ... for EACH plate. But for those of you with stock bearings or wishing to shed even a little more and want the stock bearings We Can cut separately for you. Just let us know and we can get those together. XR10 Carbon FIber Motor Plates Back in Stock !!!!! Last edited by Robbob; 04-03-2019 at 07:34 AM. |
03-18-2015, 03:13 PM | #2 |
| Re: Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates Important Installation Note The Vp plate modifies the screw location for your upper link mounts. It brings a button head screw to be flush with the top of the flanged bearing. We changed this on ours. We countersink the 3mm screw hole there so a countersunk screw is used and sits below that flange. Doing this causes the head of the screw to interfere with the bearing due to its location. you will need to file the screw head a little where it sites inside the bearing hole to allow the bearing to sit in properly. Failing to do this will not allow the bearing to seat properly causing misalignment and possible bearing failure. Below is a picture showing where to file After its filed and bearing is seated Last edited by Robbob; 03-18-2015 at 03:18 PM. |
03-18-2015, 03:14 PM | #3 |
More photos and weight comparisons. Stock Axial Motor Plate Vanquish Plate for beg bearings Krazed Builds Carbon Fiber Plate No more swiss cheesing your motor plates to drop the weight Last edited by Robbob; 03-18-2015 at 03:23 PM. |
03-19-2015, 09:27 AM | #4 |
But, I like cheese! Nice work. |
03-19-2015, 09:59 AM | #5 |
| Re: Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates |
03-19-2015, 02:27 PM | #6 |
Pebble Pounder Join Date: Feb 2014 Location: italy
are compatible with the case HR? I did not understand how many plates are necessary for completaew an axle ...
03-19-2015, 08:29 PM | #7 | |
| Re: Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates Quote:
Yes - the HR case fits on a stock Axial plate so these will fit right in. 1 plate per axle - each set is 2 plates so you can do your front and rear axles in one shot. If you are using their plate then the bearings will drop right in also. Hope that helps. | |
04-16-2015, 01:15 PM | #8 |
Second batch in stock - Ready to ship! |
05-07-2015, 04:48 AM | #9 |
Rock Stacker Join Date: Sep 2013 Location: Austria
I will soon place an order ;)
05-07-2015, 05:14 AM | #10 |
05-07-2015, 05:40 AM | #11 |
Pay Pal sent |
05-07-2015, 06:23 AM | #12 |
05-27-2015, 06:45 AM | #13 |
More in stock - Ready to ship |
07-18-2015, 05:45 AM | #14 |
| Re: Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates 6 sets left - Probably wont do another run of these unless the XR makes a come back. Been a great product run. Nothing wrong with them - just slowed down enough that we think its time to blow the rest out. $50 a pair Shipping U.S.P.S. Priority in the U.S. is included International including Canada is available same U.S.P.S. International Priority International Shipping available w/customs number |
08-17-2015, 09:48 PM | #15 |
RCC Addict Join Date: Apr 2006 Location: Minnehopeless
I'm really glad I grabbed a pair of these before they ran out! I'm totally impressed with the quality of these and the link mounts. Top notch man! |
08-19-2015, 05:08 AM | #16 |
11-23-2015, 07:06 PM | #17 |
5 sets in stock ready to ship |
01-24-2016, 09:15 PM | #18 |
"GOD SPEED" Join Date: Oct 2014 Location: Wouldn't you like to know
free bump everyone needs these Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-24-2016, 07:47 PM | #19 |
Small batch back in stock - Probably gonna be the last batch for a while with all the other projects we got coming and projected. Supports been great for these. Thank you everyone! |
11-30-2016, 05:50 AM | #20 |
Still some left in stock .......... Last batch for a while on these as our focus is turning towards other axles. |
Krazed Builds - Carbon Fiber XR10 Motor/Gear Plates - Similar Threads | ||||
Krazed Builds - XR Carbon Fiber Servo Mount | Robbob | Axles, Trannys, T-case | 4 | 08-03-2015 05:15 AM |
GIVE-A-WAY .... Krazed Builds - XR10 Carbon Fiber motor plates | Robbob | General Crawlers | 13 | 04-06-2015 06:55 AM |
GiveAway - Krazed Builds XR10 behind the motor mount | Robbob | General Crawlers | 20 | 03-31-2015 07:22 AM |
