Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: Harley's Axial Comp Chassis - "Hybrid"
Old 08-20-2008, 10:48 PM   #1
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Harley's Axial Comp Chassis - "Hybrid"
Harley Designs
Presents
The "Hybrid" Comp Chassis
Designed for the AX-10 using a DNA Dig unit.
I am offering a limited run of my Axial specific comp chassis. This chassis was modeled for tight tolerances and top performance.
This chassis was designed specifically to use an Axial transmission WITHOUT a slipper and also requires the use of the DNA dig unit. This setup is not for everyone, but I didn't design this for everyone. I designed it for the setup that I feel is the best. The recommend shocks are either Traxxas Big Bore or Losi Crawler Shocks.
The chassis is CNC milled from1/8" 6061 aluminum and the cross braces are also CNC milled from 1/4" Delrin. The bottom of the skid has two milled slots to recess the transmission mounting bolts and to help channelize the rig in a forward motion along the rocks in the case that rock were to leverage the wheels off the ground. The holes drilled and tapped in the side go into this channel as well but will not effect performance.
I have ran this rig the entire season here at KCRC, yielding me the second spot, qualifying myself for the 2008 Nationals
You will notice that I have designed a Side Skid that allows for a narrow chassis but give protection for the motor. This will guide objects that would otherwise catch the motor plate, away from the chassis so you can continue on snag free.
The chassis uses stock length upper Axial links but requires shorter lower links; this design was to gain more equal length links. The suspension was modeled several different ways and the final result is a nice low roll center with low amounts of axle steer.
This video show the axles roll center:
Tight tollerances for sure
This years test bed:
Action shots:
Don't like, don't buy it - How do you like that for a marketing strategy
But if you would like a shot at one send me a PM or Email. First come first serve, unless I don't like you
Like I said these are limited and will likely not be produced again.
Price is $74.99 shipped to the lower 48
Harley is offline   Reply With Quote
Old 08-20-2008, 11:08 PM   #2
Throwing Grenades
Harley's Avatar
Makes a great rock racer too!
It is the green XC-1 body:
http://media.putfile.com/Rock-Race
Old 08-20-2008, 11:09 PM   #3
whatever!
MOCRAWLER's Avatar
It looks neato
MOCRAWLER is offline   Reply With Quote
Old 08-20-2008, 11:26 PM   #4
DOOH!!!
MTHead's Avatar
VERY nice Harley!!! Now i understand the skid design, very unique.
I LIKE IT!
MTHead is offline   Reply With Quote
Old 08-20-2008, 11:29 PM   #5
Scale Jedi
muddauber7's Avatar
I've had the opportunity to drive this rig, more than a few times.
In one word...Planted.
Very nice piece J
muddauber7 is offline   Reply With Quote
Old 08-20-2008, 11:35 PM   #6
Thats what I am talkin about!!!! I now have a winter project
JBHardwear is offline   Reply With Quote
Old 08-21-2008, 06:54 AM   #7
Im runing one of these chassis' and I love it. Nicely done Harley/Freq E
youngblood is offline   Reply With Quote
Old 08-21-2008, 09:25 AM   #8
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Does it fit a puller? :-(
Offroader5 is offline   Reply With Quote
Old 08-21-2008, 09:30 AM   #9
Throwing Grenades
Harley's Avatar
Nope, this was designed for tight tolerances using a standard lathe motor.
Old 08-21-2008, 09:34 AM   #10
OCCUPY RCC!
dezfan's Avatar
What kind of an ASSHOLE would use this chassis?
dezfan is offline   Reply With Quote
Old 08-21-2008, 12:29 PM   #11
Throwing Grenades
Harley's Avatar
Originally Posted by MOCRAWLER View Post
It looks neato
Thanks man, I am going to run it as a rock racer down at Crawlapalooza this year.
I LIKE IT!
It's my favorite part of the design :-P
Very nice piece J
It has kept me planted on the podium all season..........right behind you
HAHAHA, see ya in Oklahoma this year.
I wondered where Neal's rig ended up Post some pictures! His was very nicely put together as well, pretty much an exact clone of mine.
A damn good looking one!
Old 08-21-2008, 12:37 PM   #12
OCCUPY RCC!
dezfan's Avatar
So who is it then?
Very nice work brotha!
Old 08-21-2008, 06:22 PM   #13
Here you go Harley. Im very glad I got the opportunity to pick this thing up from Neal. It sticks to the rocks like glue!
Just an FYI, I had to trim the side plate very little and swap the delrin cross pieces for small diameter brass tube to clear my slipper.
Thanks again for the teriffic design. It's very tight, but thats how I like it... Giggity
Old 08-21-2008, 06:46 PM   #14
Building Not Buying
CD13's Avatar
youngblood pay attention to that pup,
CD13 is online now   Reply With Quote
Old 08-21-2008, 07:08 PM   #15
65volkswagen's Avatar
I like it, what is something like this running and who can I go through to get one (if the price is right).
65volkswagen is offline   Reply With Quote
Old 08-21-2008, 09:20 PM   #16
all the info is in the first post of this thread at the bottom after all the pics
barbaricboye is offline   Reply With Quote
Old 08-21-2008, 09:42 PM   #17
I like the compactness of this chassis. Good work Harley.
'04 Rubicon is offline   Reply With Quote
Old 08-22-2008, 09:44 AM   #18
It has been almost a year since you first came up with this chassis. It is nice to see you are finally bringing it to the public. Keep up the good work. Maybee I'll get to see this rig again at Crawlapalooza.
tqcookie is offline   Reply With Quote
Old 08-22-2008, 09:47 AM   #19
Looking good .
Are you going to be running this at Saturday's comp? I would like to see it in action .
MrDublin is offline   Reply With Quote
Old 08-22-2008, 10:39 AM   #20
Billet Freak
billet works's Avatar
Killer chassis Harley! I've had a chance to play with one myself and it definitely makes a very capable rig!
Good luck on the sale.
Don
billet works is online now   Reply With Quote
You may edit your posts
