Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: BERG behind the axle battery mount
Old 02-12-2011, 08:35 AM   #1
Default BERG/XR10 behind the axle battery mount
This is my new battery mount for the berg and XR10 axles I will start cutting this next week and will be doing a run of 25 to start.
It is mabe from 1.5mm carbon fiber and 2.0mm carbon fiber. This as you can see mounts in between the motor and gear case. You will have to run longer motor screws and move the pinion out a little. The part that goes in between the motor and case is 1.5mm and that is how much you move the pinion. I have checked and you will still have plenty set screw hitting the motor shaft.
It will come with all hardware and together lncuding longer motor screws.
This will possibly work on the XR10 too I have not been able to test fit one yet.
These are up for preorder and They will ship out in the order they come in. The price is $30.00 shipped to the lower 48 send paypal to bigrons4@yahoo.com
bigron is offline   Reply With Quote
Old 02-12-2011, 09:04 AM   #2
T'is cool being first on something new.
TEDROCKZ is offline   Reply With Quote
Old 02-12-2011, 09:19 AM   #3
Will these work on the bully axles?
hootie is offline   Reply With Quote
Old 02-12-2011, 09:30 AM   #4
It is possible that it will, on a bully does the motor sit flush with the back of the gear case.
Old 02-12-2011, 10:45 AM   #5
mustangboy_347's Avatar
these look great ron ,cant wait to get mine and try it out
mustangboy_347 is offline   Reply With Quote
Old 02-12-2011, 11:43 AM   #6
Holmes Hobbies
CD13's Avatar
I'm in,PP sent,Thanks
CD13 is offline   Reply With Quote
Old 02-12-2011, 03:17 PM   #7
PP sent . Looking forward to it .
4XADICT is offline   Reply With Quote
Old 02-12-2011, 06:17 PM   #8
Money has been sent!!! Great idea
jeepsohigh is offline   Reply With Quote
Old 02-14-2011, 01:25 AM   #9
The links in the first post are each broken, any chance of the thread URL or if they are on a seperate webiste the URL for that album?
Really would be good to see how this looks mounted with a battery and on a rig. I've made an aluminium one that lays the battery down between the upper and lower links and bolt into the gear case, with this is looks like it places the battery vertical between the links??
Cheers
vodka child is offline   Reply With Quote
Old 02-14-2011, 03:51 AM   #10
Cheers
I dont have any pictures of it on the a rig this is a customers axle as soon as I get some pictures of it on a complete rig I will post them. Here is a link to it mounted on a Xr10 XR10 carbon fiber battery mount
Old 02-14-2011, 03:58 AM   #11
Thanks, that'll be great. With the Berg set up I have, not sure a vertical battery will clear the links when the axle articulates. If it does then this solution looks good and would look to pick one up.
Cheers
Old 02-14-2011, 04:03 AM   #12
I look forward to seeing this one in person. I'm hoping that my batteries will fit on this without contacting my links.
EvilTwin v2 is offline   Reply With Quote
Old 02-14-2011, 07:40 AM   #13
I plan to set this up on my super.
BTW, those are the 65:1 gearcases...
JeremyH is offline   Reply With Quote
Old 02-14-2011, 08:05 AM   #14
Lookin forward to getting mine , Cheers Ron .
CrawlinCowfreak is offline   Reply With Quote
Old 02-14-2011, 08:08 AM   #15
Hey man, when you get yours can you post up a pic of it mounted to your Berg? interested to see the link clearance on the Bergs, be good to look at yours before sticking my hand in my own pocket
Old 02-15-2011, 12:57 PM   #16
Money sent
McTwist is offline   Reply With Quote
Old 02-15-2011, 03:02 PM   #17
Ok i have sevaral orders that did not say witch axle mount they wanted. And did not put the RCC user name in also. Please put in the coments box on paypal witch version Berg or XR10
Johnanthon Wood
Allen Micheal
Gary Robinson
Steve Anderson
If this you pease pm me with the version you want.
Old 02-15-2011, 11:49 PM   #18
Pm'd ya
Old 02-18-2011, 03:21 AM   #19
racer_zh's Avatar
Intrested in a xr 10 and one for superbullys.
Wich one fits the superbully 65;1??
What is shipping for switzerland??
racer_zh is offline   Reply With Quote
Old 02-18-2011, 07:01 AM   #20
I'll be able to tell you soon (likely early next week) if the Berg version fits the superbullies....
You may edit your posts
