02-18-2011, 02:20 PM | #1 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| GCM Axial Truck Panhard Mount kit
This little kit gives you the most solid panhard mounting option for your Axial. The lower mount on the axle fits snugly in between the mounting tabs on the axle housing, and the top plate screws right into the lower part locking instantly to the axle, and providing the strongest possible mounting area possible. This will never be broken or bent, no matter how hard you drive. The frame bracket has 2 mounting holes to attach to the frame. On this setup shown here, we mounted one hole directly to the existing servo bracket and the second hole drilled through the frame to match, then securely attached. The link mount end of the frame bracket hangs down below the frame to secure your link end and lets you mount to the front or rear of the bracket. A simple and strong option that can be fitted to just about any frame. Each kit includes the Axial truck axle lower mount and hex hardware, and the frame bracket. Requires a matching link. All parts are Black anodized. Available at gcmracing.ca |
02-19-2011, 01:33 PM | #2 |
Can you post a better pic of the acle mount bracket?
02-19-2011, 03:40 PM | #3 |
here's one. The bottom part goes right up to the top flat part, and the 4 screws bolt them together. The top part has the tab for the link mounting. I have some really short travel shocks (72mm total length) on this rig and had to bend the link a bit because the diff travels up so high. On the other rigs the link is straight (90mm scaler shocks) |
02-21-2011, 03:05 AM | #4 |
Beefy!
02-23-2011, 10:24 AM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Israel
Just been on the site and it's out of stock, what a let down, I wanted to order the CC & panhard together. When will it be back in stock? |
02-23-2011, 10:42 AM | #6 |
That's ok. You can get them together next week anyway. The new lot should be in stock by mid week. |
02-24-2011, 09:56 AM | #7 |
thank you kindly.
03-01-2011, 09:29 AM | #8 |
in stock and ready to go By the way, for a SCX fitment, the panhard rod used can be a traxxas #3941, and for the GCM CrossCanyon Kits you can use traxxas #5538 or 5539 for a bolt on direct fit! Last edited by Generis; 03-01-2011 at 09:34 AM. |
03-02-2011, 04:28 AM | #9 |
Placed my order today, thanks.
