Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: Capra Shock Bottom Spring Cups
Old 12-14-2019, 10:47 AM   #1
Custom Carbon Fiber
Robbob's Avatar
Default Capra Shock Bottom Spring Cups
3D Printed Capra Shock Bottoms -
Fit Axial Capra Springs and also Associated Element Springs.
Keeps the spring centered - not able to pop off from articulation.
Easily removable with out having to take the shaft ball end off.
WILL fit any shock using a spring with outside diameter no bigger then .60''/15mm.
Comes in two versions either with or with out a .25'' external bump stop on them.
Printable in any color through Shapeways.
Krazed Builds Shapeways
With out Bump Stop
With .25'' Bump Stop
16.00$$ per set
Robbob is offline   Reply With Quote
Capra Shock Bottom Spring Cups - Similar Threads
Spring Cups CHAOTIC General Crawlers 7 04-10-2019 11:05 PM
Scaler based shock spring cups, $13.50 shipped JeepinDoug Chassis and Suspension 59 05-09-2014 08:53 PM
You may edit your posts
