Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: Paintball Gun Help!!!
Old 01-14-2008, 01:12 PM   #1
Default Paintball Gun Help!!!
I got a high voltage paintball gun and a 16oz co2 tank but when i connected it theres a small hole under the paintball gun that leaks co2 and drains it all within a hour..do u no how to stop it from leaking..thanks
KFX700 is offline   Reply With Quote
Old 01-14-2008, 01:33 PM   #2
Check O-ring, install new O-rings. Screw that f*cker in really tight.
Shaun is offline   Reply With Quote
Old 01-14-2008, 01:39 PM   #3
yep! and that hole it just there so when you unscrew the tank all the co2 dont rush back at ya. if that doesnt work get a new tank
TurnThePage is offline   Reply With Quote
Old 01-14-2008, 02:31 PM   #4
Its the tank O-ring. Replace and should be good to go.
Itch is offline   Reply With Quote
Old 01-14-2008, 02:43 PM   #5
Screw the c02 shit and get a decent carbon fiber compressed air tank. But seriously its probably the o-ring on the tank regulator.
dieselfuel is offline   Reply With Quote
Old 01-14-2008, 03:43 PM   #6
k thanks alot guys ill replace it and c what happens
Old 01-14-2008, 04:02 PM   #7
he has a high voltage man he dont need n2
Old 01-14-2008, 05:11 PM   #8
if you have a wire covered line from ur tanks screw in area on ur gun to ur regulator, then ditch that and get a plastic tube, i'm not sure the exact material but its like plastic, because that wire or i like to call mesh tubing is a huge leaker after you start taking it apart a few times.
RcFanatic92 is offline   Reply With Quote
Old 01-14-2008, 05:18 PM   #9
yea its just a high voltage to play around with...but thanks for the help and ill lyk what happens
Old 01-15-2008, 05:57 AM   #10
Macroline is what your thinking of, but don't use that with CO2. Stick with the SS braided line, much better and more durable.
Old 01-15-2008, 10:21 AM   #11
Add a little oil to that new o-ring too.
Col_Sanders is offline   Reply With Quote
