01-27-2008, 08:21 PM | #1 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
| AX vs. WK?
I have both and I'm torn between buying one or the other to replace some TLT's in a 2.2 scaler. Anyone have any opinions between the two? I like that when you flip the link mounts upside down on the WK the links are much higher than on the AX and it has the maxx size driveshafts....Buuuut if there's something I don't know fill me in.
01-27-2008, 08:44 PM | #2 | |
RCC Addict Join Date: Nov 2007 Location: BV
01-27-2008, 08:49 PM | #3 |
Well use the term scaler loosely. I'm gonna use rock stompers and an 80's Chevy body. It's on a scale frame with sliders and blah blah blah... it's basically like a show truck on 54's with rockwells.
01-27-2008, 08:58 PM | #4 |
No sure how the cases could spread at the ring and pinion when there are screws holding it together? And if thats the case Axial would have the same problem as they are the same design, only weaker plastic.
01-27-2008, 09:05 PM | #5 |
RCC Addict Join Date: Mar 2006 Location: Xxx
01-27-2008, 09:15 PM | #6 |
| Ask wrecker, he told me that, and as I said, I've not experienced this problem. Perhaps a shimming issue?
01-27-2008, 09:18 PM | #7 |
Oh, I am sure he will chime in about the "superior" Axial axles.
01-27-2008, 09:21 PM | #8 |
01-27-2008, 10:13 PM | #9 |
They are really nice. But the WK mounting is really making me lean toward them. Any reason not to go with them over the AX?
01-27-2008, 10:24 PM | #10 |
Honestly, I like my WK axles an awful lot. With the VF stalkers, my width sits at about 10 1/8th, right where I like it. The scrub radius of that setup beats everything on the 2.2 field short of a clod with the same wheels. The only downside I've found is the ground clearance. Give em a try.
01-27-2008, 11:07 PM | #11 |
I've got a pair, I just need another. With the 5.5" tires, diff clearance isn't an issue...
01-28-2008, 12:10 AM | #12 |
Rock Crawler Join Date: Aug 2004 Location: Saugus
My vote goes to wheely king. Just truss the axles so they mount up better. Here's how I did it: My WK comp rig Build, project Stein Steiger (SS) |
01-29-2008, 08:14 PM | #13 |
Another testament to the toughness of WK's.
01-29-2008, 08:58 PM | #14 |
Pebble Pounder Join Date: Aug 2007 Location: Anaheim/Gardena, CA
and the after?
01-29-2008, 09:06 PM | #15 |
He drove it off that 100+ foot cliff 3 times that I know of and all he did was pancake the body and popped some shocks apart. No broken axle parts.
01-29-2008, 09:08 PM | #16 |
Quarry Creeper Join Date: Dec 2006 Location: Bozeman
