03-17-2008, 11:52 AM | #1 |
RCC Addict Join Date: May 2005 Location: I live Here
| Drain Plug Q?
Whare is the drain plug on a Jeep NV4500 Manual Tranny ? i don't see it listed Index Number Part Description 1 Speedo Drive Rotor 2 Mainshaft Overdrive Gear 3 Mainshaft Rear Bearing Cup 4 Mainshaft Reverse Washer 5 Reverse Mainshaft Gear 6 Reverse Mainshaft Sleeve 7 Needle Bearing 8 Reverse Gear Spacer 9 Retaining Ring 10 Reverse Clutch Gear 11 Mainshaft 1st & 2nd Bearing 12 Mainshaft 1st Speed Gear 13 Mainshaft 14 Clutch Gear 15 Mainshaft 1st & 2nd Snap Ring 16 Mainshaft Inner Synchro Ring 17 Mainshaft Center Synchro Ring 18 Mainshaft Outer Synchro Ring 19 Downshift Inhibitor Spring 22 Synchro Spring 23 Synchro Clutch Key 24 Synchro Block 25 2nd Speed Gear 26 3rd Gear Thrust Washer 27 3rd Gear Retaining Ring 28 Mainshaft 3rd Gear Bearing Spacer 29 3rd Speed Mainshaft Gear 30 Mainshaft 3rd Gear Bearing 31 Synchro Clutch Gear 32 Mainshaft Synchro Ring 34 Synchro Spring 35 Synchro Key 37 Maindrive Clutch Ring 38 Mainshaft Rear Thrust Bearing 39 Mainshaft Pilot Bearing 40 Maindrive Gear 41 5th Speed Synchro Sleeve 40 Maindrive Gear 41 Maindrive Bearing Cone 42 Countershaft Rear Bearing Cone 43 Countershaft Assembly 44 Countergear Key 45 3rd Counter Gear 46 Counter Drive Gear 47 Washer Selective 48 Countershaft Front Bearing Cone 49 Retaining Plate 50 Shim Selective Kit 52 Reverse Idler Gear Washer 53 Needle Bearing 54 Reverse Idler Gear 55 Spacer 56 Reverse Idler Gear Shift 57 Maindrive Retainer Assembly 58 Maindrive Oil Seal 59 Maindrive Bearing Cup 60 Countershaft Rear Bearing Cap 61 Countershaft Front Bearing Cup 62 PTO Cover 63 Case 64 Countershaft Rear Bearing Cup 65 Countershaft Rear Bearing Shim Kit 66 Countershaft Rear Thrust Washer 67 Needle Bearing 68 Countershaft 5th Bearing Spacer 69 Rear Countershaft Bearing Retaining Plate 70 Countershaft 5th Gear Clutch Hub 71 Countershaft 5th Clutch Sleeve 72 Countershaft 5th Synchro Ring 73 Countershaft 5th Clutch Ring 74 Snap Ring 75 5th Shifting Fork 76 5th Shifting Fork Shaft 77 Extension Housing 78 Vibration Dampener 79 Mainshaft Washer 80 Mainshaft Nut 81 Extension Housing Bearing 82 Snap Ring 83 Extension Housing Oil Seal 84 Propeller Shaft Yoke 85 Rear Output Spline Seal 87 Shift Lever Assembly 88 Shift Lever Cap 89 Seat Control Lever 90 Spring 91 Plug Expantion 92 Bolt 93 Dowel Pin 94 Bare Cover 95 Pin Interlock 96 Shift Fork Pin 97 3rd & 4th Shift Fork 98 Plunger Interlock 99 1st & 2nd Shift Rail 100 3rd & 4th Shift Rail 101 1st & 2nd Shift Fork 102 Spring Shift Finger Plunger 103 Plunger 1st & 2nd Bais Shift 104 Pin Spring 105 1st & 2nd Shift Lug 106 5th 5th Shift Lug 107 Reverse Shift Fork Pads 108 Reverse Shift Fork Pad Curved 109 3rd & 4th Shift Lug 110 Plunger Reverse Overdrive Fork 111 Reverse Inhibitor Bolt 112 Reverse Shift Inhibitor Assembly 113 Pin Reverse Inhibitor 114 Overdrive & Reverse Rail 115 Plunger Detent 116 Spring 117 Plug Shift Rail 118 Gasket Back Up Switch 119 Switch Back Up 120 Breather Assembly 121 Trunnion 122 Countershaft 5th Synchro Assembly 123 Mainshaft 1st & 2nd Synchro Assembly 124 Mainshaft 3rd & 4th Synchro |
03-17-2008, 11:55 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Here ya go, Google is our friend. http://www.marylandjeepclub.org/phpB...0e1f6f9#p49390 |
03-17-2008, 11:58 AM | #3 |
thanks bro i just didn't know what pto was but from the pic that would have been my best guess but just wanted to confirm |
03-17-2008, 12:06 PM | #4 |
Yeah, that's an odd way to drain the case. Looking a little more at the search results looked like some may have drilled and tapped dedicated drain plug holes. I just searched nv4500 drain plug. Are you swapping trannies or fluids? |
03-17-2008, 12:08 PM | #5 |
fluids i searched too but i guess i just didn't type the right words |
