10-17-2005, 06:48 PM | #1 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
| Tamiya Hummer - Trials trucks
Hey.. I want to make a trails truck ... well buy one and mod from there... Are the tamiya hummer diffs metal or plastic? also how durable are the hummers... I want a scale trials truck... what do you guys recommend... I want to put a winch on it and all.. so shoot me some ideas... I did try the search feature. but didnt get results i wanted |
10-18-2005, 02:52 AM | #2 |
Rock Crawler Join Date: Sep 2004 Location: eureka
the diffs are plastic. the spider gears on the inside are metal, so is the ball-diff in the other diff. but all the other gears in the truck are plastic (except the motor pinion of course). as for durability, it seems pretty durable i haven't broke anything and dont feel that i will. winches have been put on them before so it can be done. now the things i dont like about it, i want lower gearing than what can be had. the motor can get dirt in it cause its so low(which i like for the center of gravity) and last I dont like the center drive shaft. its so tinny and weak looking (although i dont see me or anyone else having a problem with it.) other than that its a great little truck , its a blast to drive. hope that helps some |
10-18-2005, 06:39 AM | #3 |
Quarry Creeper Join Date: May 2005 Location: lost in vintage tamiya land.
I have a hummer and they are very cool and i dought they'd be too fragile unless you run 2.2 tires on em or insane power.
10-18-2005, 03:48 PM | #4 |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
I have a f-150 (same truck) with 2.2's and a lathe and it holds up to everything.
10-18-2005, 07:22 PM | #5 |
ok.. thanks for the input guys... it helps.. |
