05-29-2010, 08:31 AM | #1 |
Rock Stacker Join Date: Feb 2010 Location: Race City(Mooresville)
| Help with stampede transmission
Ok, long story short. I'm replacing the input shaft on a stock stampede(#3793). I managed to wrestle the gear off the old bent shaft but for the life in me I can't get the gear on the new shaft. What is the trick. I've tried putting the shaft in the freezer, but no go. I got both in the freezer now so we will see if that will work, but I doubt it. Any ideas? I don't have a press, or even a vise so I'm not working with a lot of equipment here. |
05-29-2010, 09:13 AM | #2 |
i know it hasn't been long since I posted but I need help. im gonna throw this thing across the yard....
05-29-2010, 09:58 AM | #3 |
Freezing both won't help any, if the gear is metal you can freeze the shaft and heat the gear.
05-29-2010, 10:05 AM | #4 |
yeah, I new that but I got the gear started on and now I can't get it back apart. I have one more idea. I'm gonna drill a hole through something and stick the shaft in it, and try tapping the shaft the rest of the way. I just hope that that works. I don't really have anything but a lighter to heat things up with.
05-29-2010, 11:44 AM | #5 |
06-03-2010, 10:47 AM | #6 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
You know I've had this problem myself quite a few times. Put a metal wheel over the gear and push down. Works for me everytime my pede, slash, or pede tranny on the ax10 goes out. Also replace that hollow cotter pin with a piece of drill bit or steel rod stock. That little guy doesn't like brushless systems and no slipper |
06-03-2010, 11:24 AM | #7 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Don't we have tech areas for this type of stuff |
06-03-2010, 11:43 AM | #8 |
06-03-2010, 12:18 PM | #9 |
