08-04-2010, 09:45 PM | #1 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| restoring a Gel cell
I have a 7amp 12v PB gel cell. It's sat for a few years and hasn't seen any use. I've started flying again and am rebuilding my flight box, and threw a tester on the battery and the voltage was very low. I have a surecharge 2010 that is a PB capable charger. I'm only getting 30-100mah per charge. is there a way to bring the battery back to life? Can I cycle it a few times to bring back some capacity or is it done dishes...?
08-05-2010, 05:31 AM | #2 |
Lead acid batteries turn into anchors if left to sit unused for long periods of time. They like to be exercised.
08-05-2010, 12:13 PM | #3 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
We sold Optima batteries when I worked for Big O tires a few years back and after I warrantied a few out for people I asked our battery guy what gives? I had them for years and never had a problem... He said if you have them in a car that sits for long periods they like to go flat... he told us to give them a 30 sec. blast with the start/ assist setting on the batt. charger then trickle charge overnight and they recover pretty good. I have saved 3 or 4 glass mat type batteries like that (they are gel also) try it and see if it works... If it blows up make sure to get video... explosions are cool! |
08-05-2010, 09:25 PM | #4 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
A standard charger that most of use have at home (whether it be a charger for car batts or whatever) isn't going to have the balls to pump the AGM batts they way they need to be to be revived. | |
08-07-2010, 07:12 PM | #5 |
I hit it a few times with the Procharger I have. and after a few more 30-100Mah peaks and discharges It started taking a good charge. sat overnight charging at 1/2 amp and was at 4800 when I left it for the wife to tend..... thats a pretty good start |
08-07-2010, 09:30 PM | #6 |
Nice |
