03-09-2006, 07:59 AM | #1 |
Newbie Join Date: Jan 2006 Location: Chesapeake Beach
| so pissed!
So I finally get my hardware today from Tower Hobbies. I ordered some 3 x 20mm screws and some 3 x 30mm screws. Turns out the 20mm ones were too short.. Ok, no problem. I have the 30mm screws. Well, the 30mm screws don't have threads all the way down the shaft, the first 20mm of it is threaded. And the parts that not threaded isn't 3mm! So now it doesn't fit. I'll either have to figure out a way to drill out my ball ends, or find a tap and die set that'll do 3mm.
03-09-2006, 08:34 AM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Tap and die set. It helps if you can't find it...........Make it.... http://www.harborfreight.com/cpi/cta...emnumber=39384 |
03-09-2006, 08:41 AM | #3 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
i'm pretty sure that du-bro makes a 3mm tap set too. should be able to get that from your LHS. as far as metric hardware goes, metric specialties in burbank california is the best! they do mail order as well. here is the website- http://www.metricspecialties.com |
03-09-2006, 10:26 AM | #4 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
true value and ace hardware have the screws for like 12 cents each.... check them out instead. thats where i get all my hardware
03-09-2006, 11:32 AM | #5 | |
