02-13-2011, 08:07 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: on the rocky trail
| bulldog winch
hey guys, want to know if i buy the bulldog 9300 will it work off a y plug from my battery? another words, can i run my crawler and the winch together? or do i have to run to batterys. the pic. on the bulldog website shows that the unit has its power source from a tamiya plug. i have a scx10. details and pics. if possable please, thankyou
02-13-2011, 09:08 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
I power mine seperate w a little 400 mah lipo and it works perfect. Havent even drawn it down to 80% w numerous pulls. Just watch if you go this route due to the controller not having a voltage cutoff.
02-13-2011, 09:13 PM | #3 |
Pebble Pounder Join Date: Sep 2010 Location: Santee
Im running mine through a Traxxas Link 4/5 channel RX with a CCBEC set at 6.0v. Has plenty of power and no winch creep. When I originally set the BEC, I set it at 6.5v and I couldnt zero the RC4WD contoler that came with the Bulldog. Oh yah, Im running 6cell NiMH stick packs. |
02-14-2011, 06:28 AM | #4 |
| thats great info but can i run it off the same battery that i am powering the truck from with a y connector?
02-14-2011, 06:12 PM | #5 |
02-15-2011, 04:30 PM | #6 |
02-15-2011, 05:18 PM | #7 | |
02-15-2011, 05:32 PM | #8 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
The winch I got from RC4WD just has a RX plug. So it is powered through the RX, which gets powered from the ESC. No need for an extra battery.
02-15-2011, 06:02 PM | #9 |
| MAke sure you drop the voltage down to around 6v. The stock controler that comes with the Bullgog will creep either in or out if too much voltage is applied to it . 7.2v may fry the controler.
02-15-2011, 06:06 PM | #10 |
| i am confused, the website shows to use a 7 cell nimd and i am getting the wireless 9300 it has no controller just a keychain remote control is the 7 cell they talking about a 7.2? or should i get a 6 cell 6 volt?? confused please help.
02-15-2011, 06:48 PM | #11 |
I apologize, I didnt realize you were getting the wireless system. Im running mine off the 3rd channel on my TX so it is actually being powered from the reciever. When it had more than 6 volts the winch would creep in or out. Im assuming that the wireless control unit has some sort of BEC so the winch doesnt get the full voltage. Again Im sorry for the confusion.
02-15-2011, 07:06 PM | #12 |
Wireless is fine on 2 cell lipo, 8.4 volt. No creep either. Dont think there is a bec as controller is very simple. I just wish they made it smaller as its oversized for what it is.
