04-25-2011, 10:19 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
| did i run my truck to hard??
i know this isnt really the section, but its not a crawler and i dont want to sign up on a new forum lol so did i run my truck to hard? it doesnt go very good any more yes the spur melted, not striped edit : thanks every one for the info that they posted, it good to know, but this isnt ment to be a serious post, just somthing to make you smile :p Last edited by ultimate_monkey; 04-26-2011 at 05:49 PM. |
04-25-2011, 11:14 PM | #2 |
Nicely done. You do know we have a non-crawler rc section, right? |
04-25-2011, 11:19 PM | #3 |
no, i didnt know that :p up untill 2 days ago when i wanted to know what servos are cool now, i havnt loged onto here for over a year
04-25-2011, 11:24 PM | #4 |
Its in the same miscellaneous section Chit Chat is in, in fact, you scroll right past it to get here...and its been there probably forever.
04-25-2011, 11:25 PM | #5 |
haha hmmm dont know how i missed that
04-25-2011, 11:32 PM | #6 |
Rock Crawler Join Date: Mar 2005 Location: Murrieta
You probly had the gear mesh too tight. Or the motor was getting so hot that it heated up the pinion, although if you did that , you probly demagnetized the motor. Either way props on the gew |
04-26-2011, 09:22 AM | #7 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
You need a new motor mount with a larger bearing in it, such as one as made by King Headz. http://www.kingheads.com/product_info.php?products_id=931 Due to an engineering oversight the bearing in the mount is too small and very problematic and susceptible to dirt and grime, it probably locked up and took out the spur and mount with it. Very common, and probably the only needed upgrade besides the new driveshaft cover which now covers the shaft near the slipper nut area. |
04-26-2011, 05:48 PM | #8 | |
thankls for the info, the bearing seems to be fine, not sticky or hard spots or any thing. the sput gear itself just phisically melted, alumimum on plastic at WOT has alot of friction. the fact that i had an area i could run my truck WOT for as long as i wanted is the cause of my problem haha, i just thought it was funny that the gear melted no striped | |
