06-03-2006, 11:33 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
| Trailer built finally
Finally got my trailer built. Here's a picture of it out on a service call, Someone had a flat. |
06-03-2006, 11:58 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: glastonbury
hahaha coool! im building one soon to tow my crawlers with my nylint. whatd you use to mount the wheels on the trailer?
06-04-2006, 03:26 PM | #3 |
The bed is a bed off the stock clod body, it's been chopped up alot so the bed has more capacity. Under the bed is a frame made up of square aluminum tube. Off the frame I used two graphite sheets with flang bushings inserted which the axle runs through. There are tube supports between the graphite sheets to make it sturdy. Then I used some aluminum wheel adapters I had from an old bolink car and mounted up the clod tires and wheels. It's a solid axle mounted with no suspension. The only suspension is in the tires flex. It works really well. I do have to say even with 4ws it's still a PITA to back the trailer up. I'm thinking about making another one only alot bigger, to haul my t-maxx around. |
06-04-2006, 04:52 PM | #4 |
very cool, does it make it up rocks with you ?
06-05-2006, 12:53 PM | #5 |
It could but it's likely to tip over given the rocks I crawl on. Then i'd just end up dragging it around.
06-05-2006, 01:06 PM | #6 |
doh. haha id love to see a trailer on a rock racer bouncing around getting dragged on the rocks haha.
06-05-2006, 11:03 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
maybe just some poser shots and some shots of it pulling the trailer on the rocks.
06-05-2006, 11:10 PM | #8 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
haha, Someone had a flat Someone had two flats!!** Nice trailer, but lengthing it would be more awesome! |
06-06-2006, 01:05 AM | #9 |
It's the bed of a clodbuster, that's how big it is, I suppose I could lengthen it but, I'm building a bigger one anyway. As for crawling it I've tried it out, the COG is pretty low with a load in the bed, the only problem is weird angles getting the hitch in a bind. But it's cool, it was mainly just something to tinker with. |
06-06-2006, 10:02 PM | #10 |
stick some threaded shaft on the end, screw on a rod end and bolt that onto the hitch on the truck. duh |
06-06-2006, 10:06 PM | #11 |
make the hitch have a rod end, and your trailer, so it makes it more flexable, I think that would work aye?
06-07-2006, 02:41 AM | #12 | |
06-07-2006, 05:37 AM | #13 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
Maybe you could try a military style hitch (AKA Pintle hitch)? Or, you could try have a ball end on your trailer, and one on your truck for twice as much travel. |
06-07-2006, 11:28 AM | #14 | |
RCC Addict Join Date: Sep 2005 Location: Lehi
06-07-2006, 12:40 PM | #15 | |
http://www.projecttwin.com/Scorpion_...awler_5081.cfm The 4th row of pictures shows the hitch. | |
06-08-2006, 07:47 PM | #16 |
this thread is worthless without pics of the truck with the trailor were arguing about! put some pics of it posing at least!
06-08-2006, 07:54 PM | #17 |
You are kidding... right? |
06-11-2006, 04:02 AM | #18 |
yeah what he said!
