06-05-2006, 03:20 PM | #1 |
Rock Stacker Join Date: May 2006 Location: Centerport
| Newbie Need Help With Project
Hey I am new to this site but not new to rc i love all the scale rigs you guys build. I need some help with my new project i want to build a iceland formula off road jeep what it is going to have is Cut HPI jeep wangler body (or some thing else if any body knows of any thing better) Pro-Line 2.2 sand paw tires i would like to build a tuber but i need help with the plans. i can draft and i can put the chassis together i get need help with shock and linkage locations i was thinking tlt axles i want to use a stadium truck transmission with a fast motor for the sand as for linkages shocks and ect. that's what i need help with any info you have for me that would be a big help thanks Last edited by wayfastwhitey440; 06-05-2006 at 03:45 PM. |
06-05-2006, 03:50 PM | #2 |
Pebble Pounder Join Date: Apr 2006 Location: watching jasoninaugusta's avatar
Looks like a fun and easy project....I wanna try it! You also might want to use the paddles from pro-line with the full spike instead of half of one.. |
06-05-2006, 04:00 PM | #3 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
sweet! i have also been contemplating this idea fro quite some time. i have a 1/6 scale willys body that i was thinking about using or maybe one of my 1/10 land cruiser bodies. i say go brushless! trans can be any but you should use the smallest one you can find. as for suspension, there doesn't need to be alot of travel and i think a 4-link or 3-link with some shorter shocks would be in order standup style! good luck and keep us posted on your project.
06-05-2006, 04:45 PM | #4 |
Looks like a way-cool project. Since it's your first build, I'd suggest going with an SW2 chassis rather than building a tuber and trying to figure all the links & shocks out yourself. Good geometry is good geometry, whether you're going fast on sand or slow on rocks, and Bender's chassis is a proven design. All you'll have to do is select some stiffer springs. There are plenty of shock mounting options so you're bound to find one you like. As for power, go brushless Get a Novak 5800 in there or wait til Castle comes out with the Mamba Max (it'll be worth the wait if it's half as good as the Mamba-25). If you're hell-bent on a tuber, then once you've found a setup you like with the SW2, just copy it with tube. You might think that buying the chassis to use as a test bed/template is wasteful, but you'll save money in the long run, trust me ;) |
06-05-2006, 05:06 PM | #5 |
sorry but who makes the sw2 chassis and does any body know of anybody that can make a tube chassis that will fit the body i want and accept tlt axles for a reasonable price
06-05-2006, 05:19 PM | #6 |
Rock Crawler Join Date: Mar 2005 Location: Murrieta
I wouldnt recomend those pro line paddles they are realle stiff and yea... the panther tires are a lot softer and come with foams and look closer to what you want http://www.hobbypeople.net/gallery/726470.asp I work at hobby people in murrieta ca, so lmk if you want them and ill hook you up |
06-05-2006, 05:21 PM | #7 |
hey thanks i will see but i really like the look if the pro line tires
06-05-2006, 05:25 PM | #8 |
thats a crappy pic on the page and Ive had the pro line ones Actually I have a set If you want them if you wana py shipping send me a pm if you want pics
06-05-2006, 05:26 PM | #9 |
and useing t maxx shafts works good
06-05-2006, 05:33 PM | #10 |
hey i found the sw2 chassis its bender custom and it looks good so what am i better off doing buying the chassis and stock tlt and the stamped tranny and selling all the left overs or buying all the stuff separate also what drive shafts do i use and i get a longer well base with the e-maxx links and are 2.2 rims a direct fit and i was thinking losi xxx front or rear shocks
06-05-2006, 05:41 PM | #11 | |
06-05-2006, 05:46 PM | #12 |
hey thanks i am going to go with the stampede tranny and lock it also what about linkage and what t-maxx shafts do i use center or wheel
06-06-2006, 08:12 PM | #13 |
Rock Stacker Join Date: Oct 2005 Location: Virginia Beach
You could use the panther tires up front and the pro lines out back to give it kind of a rugged sand buggy look. Those icelandic rigs are tough stuff. Look at pictures online to get an idea of how they're set up. They're pretty simple to figure out the suspension from pics. Good idea and should be a fun build.
06-06-2006, 09:32 PM | #14 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
wow i hope ur using a nitro motor ?? that thing will be bad *** if its anything like the real ones when its done i think i might have to make one with whats left of my hpi car |
06-06-2006, 11:05 PM | #15 | |
Pebble Pounder Join Date: Mar 2006 Location: igloo, Alaska
06-07-2006, 08:31 AM | #16 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
Moved to chit-chat - while scale, not an acutal crawler
