05-31-2012, 07:06 PM | #1 |
| Computer issues
If your not a tech, then just read everything as blah blah blah, as its a strange issue So, originally my brand new dell latitude e6420 came out of the box with a issues with the left speaker. They sent out a tech today to fix he, he replaced the speakers and the motherboard. He then proceeded to boot the laptop, ran diagnostics, ran ok. Booted windows fine. I asked him before hand if he could install some new ram i had, so he shut it all down, put it my new ram, rebooted the system, ran diagnostics and the screen went black, so he shut it off. Then he turned it back on to watch when it did it. Well it didn't shut off the next time, it froze when it was testing the clock or something (one of the very first tests). Thinking it was bad memory, he put the factory stick back in. He ran the diagnostics again and the black screen show'd its face again during the memory test. He was thinking maybe it was overheating because the back cover was still off. So he screwed the cover back on, then ran diagnostics again. Same thing, the black screen. So he called someone, that person had him hook up an external monitor, and boot the computer to windows. It booted fine and it showed the picture. He mentioned to the person he called he had the back cover off and thought it was overheating, i guess who he was talking to agree'd and figured that it was shut down long enough to hook up a monitor that it cool'd off. So the tech leaves. Thinking it was simply a overheating issue, i pulled the cover off, installed the new ram, put the cover back on, and ran diagnostics. It made it through the first section, it then asked if i wanted to run the extended memory tests, since i installed new memory i figured it be a good idea, so about a minute it, the black screen shows up. I let it stay on the screen instead of pushing the power button like the dell tech did. after about a minute the computer shut itself off. So i put the factory ram back in, and the back cover back on. It made it through the first section, but i ran the extended memory test as i was suspicious now, and it went to the black screen again. So i call the tech that has already left. He told me that i'd have to call dell and troubleshoot and if i can't figure it out then dell has to schedule a new service for him to come back out (he's been gone fore 10 minutes maybe) So i call dell, on the phone for probably 3 hours with 5 different reps (the line got disconnected for the first 3, i changed to the house phone for the 4th, house phone died, so then i called with someone elses cell. Anyways after arguing with them about the issue happening in diagnostics, not when booting windows, they finally started to try and troubleshoot it. I ended up updating the bios. But it still happened after this. So shortly after i found it was also doing it after entering the setup menu (have to wait like 30 seconds). So dell told me to run the os for extended period of time, see if it does it in windows. I forgot to mention above that after the first few times it stopped turning off the computer, instead it went to a white static screen...there was some pixels that were like color static, after a couple minutes of that it went to a pure color, one time it was white, another time it was a whiteish green depending how you had the screen tilted, and another time it was red/pink So, abit of an update, while typing the above, my screen went black again (good thing google chrome backed up this web page), so it happens while in the os as well, not just the bios. I'm thinking i got a toasted motherboard installed in my computer...any techs out there have an idea what else it could be? I'm doubting that installing different ram could cause the issues and keep the issues after installing the old ram back in. |
05-31-2012, 07:55 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Computer issues
Sounds like the video on the motherboard is bad.
05-31-2012, 08:47 PM | #3 |
| Re: Computer issues
So i was tinkering, i installed one stick of the new ram i have (I bought two 4gb sticks of crosair vengance ram...1600mhz), i booted windows and ran the use experince test (i figured this is going to push everything just as hard as the diagnostics did, but not in the bios), it worked fine. So then i swapped out to the other module, it almost makes it to the end, so i restart and try it again, gets about halfway through, so then i put the factory 2gb stick in, it lasts for barely any time in the testing, so i reboot try again, it doesn't get past login, reboot again, it quite during the bios loading screen. I think it might be overheating...the fan works, would something else with a mobo exchange be causing the heat issues? Right now it'll black screen just running the os for awhile browsing the web As for the above, there should be both onboard graphics and a graphics card...as i did upgrade from stock to 512mb |
05-31-2012, 08:59 PM | #4 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
| Re: Computer issues
It's the video. Either drivers dont match from old board to new or new board they put in is bad.
05-31-2012, 09:12 PM | #5 |
| Re: Computer issues |
05-31-2012, 09:28 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| Re: Computer issues
Yes, go to bios and reset how it boots, change from hard drive to boot from disc install disc and restart
05-31-2012, 10:01 PM | #7 |
| Re: Computer issues
So, i haven't had a chance to install the drivers...it'll go through the bios loading page and displays the boot menu for like half a second then goes to the black screen. This is really starting to piss me off, i should of just dealt with the scratchy speaker noise, hopefully tomorrow when i call them they'll just send me a new computer. lol On another note, i did manage to get into the setup menu before it started shutting down instantly. And, if i go into the system logs. All the power downs are unknow. There was one thermal event...i'm guessing that was because of my user experience test marathons But, it shouldn't overheat from running those a couple times in a row. It can't be no worse than if it tried to play a modern pc game on high settings...and only thing that should be limiting that is the grpahics and ram here's specs intel Core i7-2760QM, 2.40GHz, 6MB Cache 2.0GB, DDR3-1333MHz SDRAM, 1 DIMM, (But i bought 2 4gb 1600mhz sticks) nVidia NVS 4200M 512MB DDR3 Discrete Graphics 128GB Dell Mobility Solid State Drive, 2.5MM, Genuine Windows 7 Ultimate, 64-bit 90W 3-Pin, AC Adapter (because i went with the quad core i7, dell said i had to upgrade to 90 watt ac...could the i7 be causing the issues, or should it all be the same mobo?) |
05-31-2012, 10:13 PM | #8 |
| Re: Computer issues
Get the latest driver from the manufacturers website then uninstall the current drivers before installing the new version. Copying the drivers over top of themselves doesn't guarantee that the corrupt file is replaced. There may also be files that windows creates after the install that will not be effected by just copying the package over itself. |
05-31-2012, 10:19 PM | #9 |
| Re: Computer issues
Modern laptops can get really hot but if you didn't have the issue before the repair changing the mobo out isn't going to cause it to overheat.
05-31-2012, 10:26 PM | #10 |
| Re: Computer issues
Yea, it didn't do it before...i've had the thing sitting on a blanket for hours drawing stuff in inventor, didn't overheat...so i'm pretty sure sitting on my lap with all the air vents exposed allowing proper airlow, it can run the windows experience assement afew times in arow. The heat seems like a possible issue though, as i noticed it wouldn't black screen in the normal diagnostics if it was cool to start with, but if it was already warm from the previous diagnostics, it black screen in the quick tests not the thorough test I can't even boot windows now to try and get drivers... |
05-31-2012, 11:05 PM | #11 |
| Re: Computer issues
If it is happening in the bios it is not a driver issue. Drivers have no effect there. It really sounds like an issue with the video chipset, which means motherboard on most laptops. Power it on and tap f12 when you get the dell logo. There is a diagnostics you can run from there. If you have an issue it will give an error code, write it down or take a pic of it. Give the error code if present to the dell tech when you call, it should save you that run around BS they try and pull. |
05-31-2012, 11:11 PM | #12 |
| Re: Computer issues
If they replaced the mobo with the same one it really shouldn't have caused a problem. I go through 1-2 graphics cards a year and I've seen the type of colored screens you were getting from a dying card several times. Which is why I think it's hardware. With windows though you never know. Something during the repair could have corrupted windows or driver files. If you want to try getting back into windows go into safe mode and uninstall the nVidia driver package and reboot. This will force windows to use a generic vga driver for the video card and may let you back into windows if that is the problem. From there you can surf to the nVidia website to get the latest drivers or if you have a thumb drive you can d/l on another pc and tranfer them to the laptop. Start your computer in safe mode |
06-01-2012, 12:20 AM | #13 | ||
| Re: Computer issues Quote:
It seems if i let it sit for 30 minutes or so turned off then it works ok for alittle while then starts acting up again...i notice the fan is blowing some HOT air around this time as well. I got it to boot up to windows here not too long ago, and started to download the nvidia driver for it, but it shut off while i was downloading. Also, i can't find the nvdia graphics in my device manager...would it have a generic name? Also, i think the new card is soldered to the mobo, its not removable. I did some research before ordering, as i wanted a bigger graphics card, and from what its more then less permanently attached, so it could very well be a mobo issue as its not the gpu from before the mobo replacement. I was outside cleaning air filters for all my toys (atv's, dune buggies, my dd, etc.) while the tech was doing his thing, so i don't know what exactly was replaced/stayed the same | ||
06-01-2012, 02:37 AM | #14 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
| Re: Computer issues
ok Losikid you have bad motherboard. I have seen this numerous times. The reason I can say this as I was a Dell tech support rep for 6 years. they gave you a faulty board or the tech did not install the heatsink properly/ bent one of the exchanger pipes. If the system is less than i think 14 days old you can call customer care and get a brand new one. After that I do beleve it will go to tech support. Call in and get a new system would most likely be easier in the long run vs sending a tech out. only issue with that would be it may take a little longer to do so.
06-01-2012, 05:51 AM | #15 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Computer issues
Not necessarily a bad motherboard, though that's one good thought. Because it starts then freezes, it is a heat issue...problem is from what. Runs longer when cooled off before hitting the black screen. Most commonly the issue is lack of heatsink properly seated on the processor, especially in laptops. I've seen it happen and the processor shuts down to save itself from destruction. Sometimes you'll get 1 minute before going black, sometimes it can be 10 minutes. |
06-01-2012, 07:43 AM | #16 |
| Re: Computer issues
Binaryterror is right on that one. Not saying the whole board is bad but the temp probe on the motherboard may be. It is heat related. Hell I have even seen them with bad solder job on the inside of the board and heat would cause lockups similar to this.
06-01-2012, 07:55 AM | #17 |
| Re: Computer issues
also the tech may have pinched the wires from the mb to the screen, had this happen and caused major heat issues, blk screen etc. I think you should call them and get a replacement asap.
06-01-2012, 08:09 AM | #18 | |
Didn't realize you had a secondary card. The Video card you have in there is either not seated properly or the fan didn't get hooked back up when the tech swapped the motherboard. That is whats causing the card to overheat and screen go black. Done enough times it will kill the card if it hasn't already Last edited by BUBBA069; 06-01-2012 at 08:11 AM. | |
06-01-2012, 11:43 AM | #19 | |||||
06-01-2012, 11:46 AM | #20 |
Computer issues - Similar Threads | ||||
need some help with my computer | peyton. | Chit Chat | 14 | 07-22-2011 05:54 AM |
need computer help | badltl510 | Chit Chat | 0 | 11-06-2007 07:33 PM |
Computer help! | smokinubyrc | Chit Chat | 37 | 09-29-2007 07:10 PM |
