09-26-2006, 01:23 PM | #1 |
Pebble Pounder Join Date: Jan 2005 Location: Mission, B.C.
| Formula 4x4 motor/esc ideas
As the title states I am just starting the process of building a scale formula 4x4 ( those crazy Icelandic hillclimbers ) based off Tlt axles and a tube chassis and was looking for ideas as to which motor/esc combo would be good as it needs both low end and top end power. I also hope this is the right forum for this question, if not please move to right one for me. Thanks in advance Jerry |
09-26-2006, 03:38 PM | #2 |
Pebble Pounder Join Date: Jun 2005 Location: Gilroy
brushless would get my vote.
09-26-2006, 04:16 PM | #3 |
What scale are you talking about? I mean brushless would be nice like the one for the e-maxx but i'm not sure that the axles would hold up unless you get the ones RC4WD plans on making. You could use a gorillamaxx tranny and the brushless system to go along with it and once RC4WD releases the machined TLT axle cases. i think that would suffice
09-26-2006, 04:48 PM | #4 |
It will have the pro-line 2.2 sand paw tires on it and a Matt Francis trans in it and should be fairly light. I was thinking brushless just unsure of which set up to use ( ie. Holmes hobbies revolver or one of the novak systems or ???? )
09-26-2006, 04:53 PM | #5 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
I think JRH can get you the novak system now also wheel speed is paramount for that kinda stuff.....id go with at least a 2450KV inrunner motor or better | |
09-26-2006, 05:25 PM | #6 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
JRH really liked the crawler novak setup. He said it might be the best trail rig combo out right now.
09-26-2006, 10:44 PM | #7 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
rockwerks is right, wheel speed is very important. Those guys even run across small ponds. If you go brushed, you will need a modified motor somewhere in the 15X2 or so range. But if you go brushless get a higher kV model. Just remember the real machines are purpose built and designed to run a minimum amount of time kinda like a top fuel or rail dragster. So you might have to make a concession on how much like the real thing you want to build.
09-29-2006, 03:55 PM | #8 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
I want to see this thing, hurry up and build it and take lots of pics, waiting impatiently |
09-29-2006, 05:12 PM | #9 |
You're going for max wheelspeed here, rather than torque or low-speed resolution, so look into the Mamba Max (the 4600 should be plenty) or the Novak Velocity 5.5/GTB combo. You'll want to lay the tranny down, as both motors are fairly heavy. The Mamba is water-resistant. If you want to make it a dual-purpose rig, the Novak Crawler might be worth a look. It's 2700 KV isn't that fast, but it's got enough balls that you can gear it way the hell up for speed, and back down when you want to crawl. |
10-02-2006, 11:08 AM | #10 |
It is sounding like the novak crawler is the way I'm gonna go, I have heard lots of good things about it so far. But the mamba being waterproof sounds good.... Oh yeah I am just waiting for some parts then I will start posting some pics in the scale section
10-02-2006, 11:41 AM | #11 |
Newbie Join Date: Feb 2006 Location: Soldotna
I would love to see some pics, as I am starting a similar project. Trying to find some mad force axles for mine. My goal is to be able to hydroplane a small pond. Wheel speed is definatly going to be your biggest concern... Good luck, and pics? |
10-02-2006, 03:21 PM | #12 | |
Quarry Creeper Join Date: Mar 2006 Location: the great brown north=(WI)
forrc water skippin i'd take a st and do sand tires all around and slam it down low and put lexan sheets on all the a arms | |
