10-15-2006, 03:00 PM | #1 |
Rock Crawler Join Date: Aug 2006 Location: nc
| LEDs
ware can i get a cheap but brigt kit for head / tail lites.
10-15-2006, 03:27 PM | #2 |
Quarry Creeper Join Date: Mar 2006 Location: Juneau Alaska
You can try Ram rc lights at http://www.ramrcandramtrack.com/ . they also can be found at Tower Hobbies Steve |
10-15-2006, 03:57 PM | #3 |
they were to much $ . if i made one how much would it coast for parts .what parts would i need.
10-15-2006, 04:01 PM | #4 |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
Radio Shack?? Cheap Azz... LOL
10-15-2006, 04:01 PM | #5 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
Man you must be really cheap $21.99 I thought was a good price. 4 led's, wire, voltage reducer, and a 9Volt battery clip. I bet you are really close to the $22 price tag.
10-15-2006, 04:05 PM | #6 |
i just thougt you could make one cheaper. i was asking how much would it be to get parts from radio shak
10-15-2006, 04:40 PM | #7 |
If you want cheaper pass by radio shack and go strait to thee source http://www.theledlight.com/5mmcoloredleds.html . As for the other stuff you will need for making light setup go to the five and dime second hand store by a $.25 toy and get the 9 volt lead and wires. Steve |
10-15-2006, 04:53 PM | #8 |
there cheap but are they bright. this might be dumb but it says 12 pieces for $.85, is that 12 lights.
10-15-2006, 05:58 PM | #9 | |
Yup that is 12 lights for .85 and yes they are bright just look at the Intensity mcd rating. Steve | |
10-15-2006, 06:10 PM | #10 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
I like www.lsdiodes.com. They have a good assortment and no minimum to buy.
10-15-2006, 06:42 PM | #11 |
Another thing you can do with the led light is to make a headlight capsule. To make one get a couple of disposable cameras from wally world camera shop, or any other camera place. They usually will give them out free. to make them take the camera apart be carful not to short things it hurts like hell. Take out the flash reflector (FL1). drill a hole in the back for the led and CA glue it in place, then take a piece of alluminum foil or something very reflective and glue on the tip of the led and there you have a directed headlight for your ride. Mount it directly to your body of to your chassis. Looks realy graet in blue. Steve |
10-16-2006, 06:38 AM | #12 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
Damn good Idea BOB.... For sake of ease for headlights i pick up a pre assembled "flasher" kit from radio shack... It holds 2 "aa" and has a switch built in. Cut the flasher board off and in series place 2 high intensity white LED's and a 51 ohm resistor (or blue potentiometer that can be tuned to vary brightness) the cost is like $5.00 flasher kit (cheapest battery/switch combo) $10.00 super bright led's (2) white (they are expensive cause they are a blue and yellow stacked to make the white color) $1.00 max for the resistor or $2 for potentiometer(rheostat) $4.00 wire NOT having to hastle with soldering and modifying $22.00 PRICELESS |
10-16-2006, 10:26 AM | #13 |
Quarry Creeper Join Date: Sep 2005 Location: VARCOR
Try ebay!! The seller rc-lights has 4 white and 2 red sets for $21.50 shipped or 2 white and 2 red for $18.50 shipped. All his light kits come pre-wired and have a on/off switch in the tiny battery box. Takes 3 AA batteries. Super bright I have a set on my Blizzard.
