02-14-2016, 12:25 PM | #1 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Anyone heard of this?
Just got this from an RPP Hobby email... __________________________ 1.9 ibex tuber Slash that got run over by reindeer R.I.P Dave Mirra Cheers Jacob |
02-14-2016, 12:35 PM | #2 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Anyone heard of this?
The slop between this unit and almost every axle shaft I've tried in it is unreal, Almost as bad if not worse than the Hot Racing spool. For most this wont be an issue, however, If doing the XR mod, You need as much meat inside the spool as possible as you are grinding away at the XR axle shaft to allow it to work... The Holme Hobbies spool is BY FAR the tightest as far as slop is concerned, ALMOST to a fault, I've had to tap in my fair share of axle shafts to HH spools. .. To some ( xr mod guys ) This is what you want.. One more thing to note, These are of lower quality steel than HH uses.. All things said, Its a great budget option locker. For the price, I'd argue the best.. |
02-14-2016, 12:41 PM | #3 |
Wow that's surprising. I would think a "Vanquish" owned company would make a badass product. __________________________ 1.9 ibex tuber Slash that got run over by reindeer R.I.P Dave Mirra Cheers Jacob |
02-14-2016, 12:43 PM | #4 |
Really the last line of my post should say it all tho, Its a budget option, It fills that roll very well, Better than any other option.. Just if you are planning to do an XR mod down the road, One might reconsider putting these lockers in is all |
02-14-2016, 01:20 PM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
Are good lockers really what's breaking the bank for people?
02-14-2016, 02:33 PM | #6 |
| Re: Anyone heard of this? |
02-14-2016, 04:51 PM | #7 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
02-14-2016, 05:55 PM | #8 |
02-14-2016, 06:24 PM | #9 |
02-14-2016, 06:30 PM | #10 |
02-14-2016, 06:52 PM | #11 |
Rock Crawler Join Date: Oct 2012 Location: Casper
Sometimes, it is.
02-14-2016, 07:16 PM | #12 |
Holmes and harley said the problem isn't really in the manufacturing, the problem is that the axial tolerances vary quite a bit.
02-14-2016, 07:52 PM | #13 | ||
| Re: Anyone heard of this? Quote:
Yall might be interested in our new prices on lockers. I made them less expensive to be competitive, although I probably didn't need to do that based on the difference in features. | ||
02-14-2016, 07:56 PM | #14 |
I hope they didn't use the same broach as the 2 piece design lockers. The shaft will damned near spin 360 unless the grub screws are tight. |
02-14-2016, 07:59 PM | #15 |
| Re: Anyone heard of this? It seems to be the same tool. I should probably look into broaching mine as well, but it would be a pain to program the machine for it.
02-14-2016, 08:13 PM | #16 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
02-14-2016, 08:17 PM | #17 |
I think the diameter of the shafts where they are grinding flats is less than 5mm, so it doesn't have much to hold against rotation.
02-14-2016, 08:20 PM | #18 |
| Re: Anyone heard of this? Yup. You catch just a little bit of the fat end and the rest is a smaller diameter. You really want a tight fit for a long life.
02-15-2016, 08:56 AM | #19 | |
02-15-2016, 09:06 AM | #20 |
Not knocking VP, but it looks these are coming in at $18.99, and it looks like Locked Up just dropped their FI spools to the same price. I've been hammering the FI spools for a couple years on a various rigs and never had an issue, and more importantly there is no slop between the locker and axle shafts. Matter of fact all my axles required a bit of massaging then tapping to seat them, no worries on slipping or getting hogged out over time.
Anyone heard of this? - Similar Threads | ||||
Anyone heard of this? | Bmxreeves | Electronics | 0 | 11-17-2015 08:03 PM |
has anyone else heard of it | grizz | Chit Chat | 19 | 08-22-2008 02:33 PM |
F what ya heard | PROTOTYPE | Chit Chat | 3 | 05-16-2008 05:44 PM |
anybody ever heard/seen one of these (old RC) | STANG KILLA SS | Chit Chat | 8 | 09-08-2007 07:24 PM |
What i have heard | pinkfloydman | Tamiya Txt-1 and Juggernaut | 2 | 05-26-2004 02:32 PM |
