09-21-2016, 10:05 PM | #1 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Bigger than a Bomber Last edited by twissted; 09-22-2016 at 07:24 PM. |
09-22-2016, 05:21 AM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: Bigger than a Bomber
whi is this here? didn't you already put this in big rig section?
09-22-2016, 05:59 AM | #3 | |
| Re: Bigger than a Bomber Quote:
It'd be interesting to see some of his rigs doing something other than driving around on level ground. I got burned out on bashers after a short time so I don't pay attention to them around here either. | |
09-22-2016, 06:28 AM | #4 | |
Figured maybe a bit of chit chat love might get his attitude straightened out. | |
09-22-2016, 06:31 AM | #5 |
oh, well... im bad for having unfinished projects..
09-22-2016, 11:30 AM | #6 |
I deleted his same thread in the Bomber section.
09-22-2016, 12:05 PM | #7 |
Moderator Join Date: Jan 2004 Location: chicago
i dont know why it always has to be a 'better than X' theme. i also dont know why you continue to push peoples buttons here time and time again... do you not see that you are either chastised or ignored for being a bit of a pest and alluding that whatever you are throwing together over a weekend is better than the rigs in the dedicated sections that you are inappropriately posting in? just build something and post it in the right section. in this case KYOSHO. call it a bomber killer if you want, but post it in the right section. |
09-22-2016, 01:09 PM | #8 |
If he put it where it belongs he wouldn't be able to spread his message.
09-22-2016, 01:35 PM | #9 |
| Re: Bigger than a Bomber |
09-22-2016, 02:54 PM | #10 |
| Re: Bigger than a Bomber Last edited by twissted; 09-22-2016 at 07:25 PM. |
09-22-2016, 03:06 PM | #11 |
09-22-2016, 03:13 PM | #12 |
RCC Addict Join Date: Aug 2008 Location: Paulina
09-22-2016, 03:18 PM | #13 |
So just how do you know nobody including any of us has been able to build a rig running 4s, 150 amp esc with solid axles that didn't have torque twist? You don't, if I bothered to plaster all of my rigs on the forum you'd know my bouncer fit that bill exactly other than battery choice since I ran it on 45c turnigy. What does that prove? Nothing. Just like your declaration as being the best builder on the forum, it means fawk all. |
09-22-2016, 03:47 PM | #14 |
Hard to see out of the box if you don't take a look!
09-22-2016, 03:55 PM | #15 |
| Re: Bigger than a Bomber Last edited by twissted; 09-22-2016 at 07:26 PM. |
09-22-2016, 04:05 PM | #16 | |
I tore it apart and sold the trans and I'm using the axles to build another crawler but this is/was it. No video because I know what it looked like and I don't care if some schmucks online likes it or not. Heavily modified TCS crawlers eclipse chassis, built ar60's, bombproof trans, 2350 4 pole sensored 1/8 scale motor powered by a 150A trackstar esc. Shock setup and simple link placement locked down the torque twist. Not rocket surgery by any means. | |
09-22-2016, 04:42 PM | #17 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I dont you about y'all, but the builds I'm most impressed with are scale styrene creations. If it works for you, fantastic. Some of us aren't into the large scale stuff, but that doesn't mean all of our bombers, scx and wraiths are garbage compared to a kyosho |
09-22-2016, 05:00 PM | #18 |
09-22-2016, 05:08 PM | #19 |
| Re: Bigger than a Bomber Last edited by twissted; 09-22-2016 at 07:27 PM. |
09-22-2016, 05:09 PM | #20 |
Bigger than a Bomber - Similar Threads | ||||
Making Crawling bomber into trail rig bomber. | theTman | Axial RR10 Bomber | 2 | 06-10-2016 01:46 PM |
