10-07-2016, 02:52 PM | #21 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: stainless hardware or?
magnesium
10-07-2016, 09:24 PM | #22 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: stainless hardware or? |
10-07-2016, 11:46 PM | #23 |
Quarry Creeper Join Date: May 2009 Location: India
| Re: stainless hardware or? I use right angled Allen keys by TVS or Unbreko. Both are reliable brands. I ruined an Allen key while using a M3 SS bolt to self tap an insert into an aluminium job. In this case , the torque was way higher than what is usually needed.
10-07-2016, 11:52 PM | #24 |
10-08-2016, 12:37 AM | #25 |
Moderator Join Date: Jan 2004 Location: chicago
holy shitsnacks the timing on this couldnt have been any better... ive had my scalers in storage for close to a year now, not a big deal UNLESS you used a rock salt technique to patina your tf2 and use the cheap rc4wd black oxide screws. every single black oxide screw that was touching the body rusted up like crazy. condensation or something... image is the yota cab mounting brackets, i had to drill off the buttonheads and work the screws loose with pliers. in case i didnt make sense heres where the salt came from. i used it like you do with watercolors to make the ink cluster up... obviously didnt seal it up good enough. |
10-08-2016, 12:40 AM | #26 |
^the nuts you see in the bed.. had to snap all those off they were rusted so bad. then the tapped aluminum posts underneath were all corroded as heck. meh... phoey. |
10-08-2016, 06:23 AM | #27 |
| Re: stainless hardware or? Was that a steel nut on an aluminum post? I'm assuming so since you said they were rusted. Galvanic corrosion is a problem too.
10-08-2016, 09:51 AM | #28 |
stainless hardware or? - Similar Threads | ||||
Yeti Stainless Hardware Kit from Team KNK Hardware | Team KNK | Axial Yeti | 23 | 07-03-2016 11:35 AM |
Team KNK Hardware Stainless Steel BULK Hardware and kits | Team KNK | Tools and supplies | 23 | 02-15-2016 04:41 PM |
Stainless Hardware Kits from Team KNK Hardware NOW AVAILABLE for the Ascender | Team KNK | Vaterra Ascender | 4 | 04-03-2015 07:00 PM |
NOW AVAILABLE Twin Hammers Stainless Steel Hardware Kit from Team KNK Hardware | Team KNK | Vaterra Twin Hammers | 5 | 01-15-2015 10:17 AM |
Team KNK Hardware Stainless Steel Bulk Hardware and Kits | Team KNK | Vendors Market | 17 | 01-15-2015 10:11 AM |
