08-13-2007, 07:30 PM | #1 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
| Upgrading my Emaxx... radio system ????
hi...well i have a traxxas emaxx my porblem is my tq3 reciever doesnt work anymore and the control barely works:-( and i want to know something.... if i change the shifting servo for other stronger and faster.... i will shift faster and without quit the throttle? ok so a good 3 channel radio that works with my emaxx? spektrum dx3 or 3.0 JR XS3 Futaba 3PM 3-Channel Airtronics MX-3 Hitec Aggressor SRX 3 Hitec Aggressor suggestions ..??????? thanks Last edited by andres-tavares; 08-13-2007 at 07:33 PM. |
08-16-2007, 08:39 AM | #2 |
any?
08-16-2007, 08:44 AM | #3 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
Is there a mini servo for your 3rd channel now? or is it standard size? if its mini try a hs-85mg metal geared servo. But i still think you will hve to let off when you shif...or be prepared to replace gears
08-16-2007, 10:28 AM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Specktrum I love my dx3. |
08-16-2007, 10:31 AM | #5 |
Pebble Pounder Join Date: Nov 2005 Location: Viva Your Mom!!
get a futaba 3pk thats what i gots
08-16-2007, 11:57 AM | #6 |
RCC Addict Join Date: May 2006 Location: Aroostook county
DX3 baby |
08-16-2007, 01:37 PM | #7 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
about the only thing i can help you with is the shifting servo. if you get a faster one, not neccesarily more powerful, i assume it would shift faster, presuming you let of the throttle and hit it again fast enough. no i don't think it will shift without letting off the throttle, i think there is something incorporated in the tranny which doesn't let it shift when torque is being applied to it. i could be wrong though. I highly reccomend replacing the stock 2055 steering servo with something more powerful though, i plan to get another hitec 645mg servo for mine. a friend of mine has one in his tmax and it'll turn the front wheels like they aren't even there, even when standing still. it's also more responsive and quicker than the original -Dalton |
08-16-2007, 02:18 PM | #8 |
Rock Stacker Join Date: Jul 2005 Location: Strongsville
the stock servo for the trans should be fine - no matter how fast the servo is you'll still have to let off on the throttle as already mentioned, it's pretty much the way it's designed. As far as that TQ3 goes, I've never had a problem - If you're looking for upgrades for the EMaxx you might consider upgrading that steering servo to the Hi Tec HS645MG, upgrade your axle and drive shafts to metal cvds, put some sway bars on the front AND rear - and then swap out those stock shock springs for black dual-rates and change your shock oil- i'm sure there are different schools of thought on the shock oil weight, myself I run 30 and then position the shocks on top all the way in and on the bottom all the way out. For me this made my maxx VERY stable, and very solid. A friend of mine and I got EMaxxs pretty much at the same time - his is bone stock and mine is as mentioned above - I can out-everything him with mine. Hope this helps |
08-17-2007, 01:06 PM | #9 | |
no i have the stock servo.. wich is a standard size... its the 2018 i think thanks | |
08-17-2007, 01:08 PM | #10 |
08-17-2007, 01:10 PM | #11 | |
well i will let the stock shifting servo ... thanks and i already have and install a hitec 645 on the steering thanks | |
08-17-2007, 01:14 PM | #12 |
Rock Stacker Join Date: Aug 2007 Location: monongahela
| e-maxx
I had a e-maxx when they first came out,never had to let off the trigger to shift to second gear??
08-17-2007, 01:22 PM | #13 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
dx3, enough said.
08-17-2007, 01:58 PM | #14 | |
i already have a hitec 645 on my emaxx for steering driveshafts: mine are stocks ... when something broke i will buy revo ones shocks: i have big bore withnthe stock oil ... btw they're too soft so i have to buy a heavier oil well i dont know wtf are the sway bars on the emaxx ... what are they for? another mod will be a spool on the rear for more climbing power ... and maybe some swamp dawgs but my first problem is the radio system .... the spektrum is winning ... the dx 3.0 where its the cheapest place to buy it? ...ebay? Last edited by andres-tavares; 08-17-2007 at 02:08 PM. | |
08-17-2007, 02:04 PM | #15 |
08-17-2007, 02:22 PM | #16 |
08-17-2007, 02:24 PM | #17 |
| i dont doubt it... must be awesome! but its to expensive for me... i think can get a spektrum dx3.0 with reciever and no servos for 150$ or less thanks Last edited by andres-tavares; 08-17-2007 at 02:27 PM. |
