08-17-2007, 08:36 PM | #1 |
Rock Crawler Join Date: Aug 2006 Location: nc
| 1:18 car project kinda sorta
i want to make this ( http://cgi.ebay.com/1968-MERCURY-COU...QQcmdZViewItem) into a rc. would you just put the electrics into using the stock frame or would you buy some sort of base car and what car would work best. also doest have to performe good just work. more of a show than go |
08-17-2007, 08:41 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Best bet would be find a cheapy rc at Walmart/ToyRus/etc..............and try to fit the body. Outside of that not having a functional rear axle or trans or anything, the rest of it would still be a PITA to make into RC. You would have to create EVERYTHING from scratch. It you are set on the Cougar (excellent choice of auto btw), I would go ahead and get the kit..............then search for an rc with just about the same width and wb to stick under the body. edit: actually, I have two el-cheapo 1:18 (toy grade) RC chassis' sitting around right now. If you can match up the width/wb, I could pretty much give you the guts of them because I just want the bodies. Last edited by Robb; 08-17-2007 at 08:45 PM. |
08-17-2007, 08:42 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Maybe an HPI Micro RS4 would work for a chassis to put under it.
08-17-2007, 08:42 PM | #4 |
Pebble Pounder Join Date: Nov 2005 Location: Viva Your Mom!!
get the body off that thing and make a chassis, or see what your working with first
08-17-2007, 08:52 PM | #5 |
im defently getting the cougar and doing a scale version of my 1:1. i had the modle already but someone threw it away when my basment flooded.
08-17-2007, 09:21 PM | #6 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
Id slap the body on an older pan car. Possibly modified to fit the wb. Pan cars are nice as they are flat and super simple.
08-17-2007, 09:27 PM | #7 |
will i be able to keep the seats ans some under hood detail?
08-17-2007, 09:42 PM | #8 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
Yes you would. you can build your own chassis. I would suggest using lexan to do this its very easy to work with. Since its a pan car the chassis is completely flat only thing to worry about is counter sinking a few holes.
