Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: Toyota motor help (22r/22re)
Old 01-05-2008, 05:48 PM   #1
TLTCrawlin's Avatar
Default Toyota motor help (22r/22re)
OKay my dad and I are rebuilding a 85 toyota 22r/22re, and he bought a head from a guy, that said it would work but its a 84 (little different).
We cant get the timing chain onto the cam, we're thinking the 84 head is a little taller, anyone know what the problem could be?
TLTCrawlin is offline   Reply With Quote
Old 01-05-2008, 06:05 PM   #2
i will double check on that for ya. it's been awhile since i worked on those. i think the 84 has pop up pistons. different than the later 22r's.
chino438 is offline   Reply With Quote
Old 01-05-2008, 06:09 PM   #3
TLTCrawlin's Avatar
Thanks, i found on toyota nation that the newer 22r (85+) has a smaller piston and taller head and block
Old 01-05-2008, 06:10 PM   #4
I had a 22R head on a 22RE engine when I bought the truck (used) figured out that if you bust off a full link and replace it with a half-link, it will work fine.
dezrik is offline   Reply With Quote
Old 01-05-2008, 09:26 PM   #5
Natedog's Avatar
Deck height, piston tops, compression, exhaust manifold to head bolt pattern, compression is different. I'd find the right head. 81-83 22R same, 84-88 (and maybe later) are basically the same.
Old 01-05-2008, 09:57 PM   #6
TLTCrawlin's Avatar
He is gonna put this head for sell and buy the correct one.
Old 01-05-2008, 10:35 PM   #7
84 was also the last year of the double row timing chain I think...
tim the toolman is offline   Reply With Quote
Old 01-05-2008, 10:36 PM   #8
TLTCrawlin's Avatar
Thanks guys!
Old 01-05-2008, 11:04 PM   #9
I did the same thing, except my block was an 85+ and I had my old head ported, polished, etc etc. I ended up swapping blocks since I already had the headwork done
gtxracer is offline   Reply With Quote
