Go Back   RCCrawler Forums > Miscellaneous > Comments, Suggestions, and Help
Thread: 1.9 comp subforum
Old 11-27-2008, 04:34 PM   #1
Default 1.9 comp subforum
why don't you guys make a 1.9 comp section for people who are hand building 1.9 comp rigs. the losi is pretty much the only out of the box 1.9 comp class rig, but i know people who are thinking of building them from narrowed axles and other stuff.
puryear is offline   Reply With Quote
Old 12-01-2008, 09:25 AM   #2
Diggin' the new SCX10 II!
badger's Avatar
The only forums that are listed with 1.9 or 2.2 are the scale forums. All our tech forums for comp related rigs are based off the type of axle used in the build. So unless your building custom 1.9 axles (in which case you need to give me a set or I will ban you), then you should be posting your custom comp builds in the Losi forum.
badger is offline   Reply With Quote
