Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: cliff climber set ups ?
Old 08-15-2008, 10:18 PM   #1
Default cliff climber set ups ?
just got mine today and i was wondering how you guys are setting yours up. i seen the oring and clod stall talk, anything more ?
twisted is offline   Reply With Quote
Old 08-15-2008, 10:47 PM   #2
i personally dont like the cliff climber. And i dont know much about it. But what i can say is, try to mount the battery lower somehow. also possibly drill holes in the rims. And maybe cut the tire foams. Post some pictures when you done setting it up. Maybe they will change the way i feel about the cliff climber
EDIT: just saw how many posts you have, and im guessing you allready though of those ideas=]
littleWOJIN is offline   Reply With Quote
Old 08-15-2008, 11:27 PM   #3
yea i know pretty much all of the normal stuff i was just curious as to how people that have had them for a bit have worked out any bugs or found some different things that work.try to get the ball rolling on this crawler.
Old 08-15-2008, 11:43 PM   #4
OCCUPY RCC!
dezfan's Avatar
Mine is in a pile!
dezfan is online now   Reply With Quote
Old 08-15-2008, 11:57 PM   #5
Originally Posted by dezfan View Post
Mine is in a pile!
using the parts for a build or junk ?
Old 08-15-2008, 11:59 PM   #6
OCCUPY RCC!
dezfan's Avatar
Some parts are being used, others are not!
Old 08-16-2008, 12:05 AM   #7
a little more detail ? maybe ???
Old 08-16-2008, 12:13 AM   #8
OCCUPY RCC!
dezfan's Avatar
Soon Grasshopper............very soon.
Old 08-16-2008, 12:30 AM   #9
Your using a Grasshopper chassis... That'll suck.. You can't build Sh!t.
run2jeepn is online now   Reply With Quote
Old 08-16-2008, 12:35 AM   #10
OCCUPY RCC!
dezfan's Avatar
Well it's actually a Hornet chassis.....................
Old 08-16-2008, 12:55 AM   #11
hmmmm, i may have to copy your build... i have both a cliff climber and a grasshopper. my hopper is original though so your build will have to impress me.
Old 08-16-2008, 12:59 AM   #12
OCCUPY RCC!
dezfan's Avatar
Better sit down then!
Old 08-16-2008, 02:12 AM   #13
Hmmmmm. Pimp cane
lucky13offroad is offline   Reply With Quote
Old 08-16-2008, 08:21 AM   #14
midgit pimp cane
hairba11 is offline   Reply With Quote
Old 08-16-2008, 08:48 AM   #15
Shut up Dave
jetboat's Avatar
Im working on a mini stick chassis for mine... mounting the heims is turning out to be the difficult part
jetboat is online now   Reply With Quote
Old 08-16-2008, 06:20 PM   #16
R/C Investor
sgil2001's Avatar
I did the following to mine:
1) Took tires off and put 3 oz of lead in front and 1 oz in rear. Replaced stock foams with memory foams.
2) Installed 11t pinion on rear motor.
3) Removed rear steer and locked it.
4) Made 7 cell pack of 2/3A cell and put on front servo.
Radio is 2 ch. Futaba. Steering servo is Hitec 645MG. ESC is Mamba 25 with Dimension Engineering BEC.
sgil2001 is offline   Reply With Quote
Old 08-16-2008, 10:15 PM   #17
the 11t on rear help with the clod stall ? have you any issues with needing the orings in the drive cups ?
Old 08-17-2008, 08:16 AM   #18
R/C Investor
sgil2001's Avatar
Yes, I forgot about that. I did need o-rings.
The 11t in the rear helps some. When I get time I'm going to rewire my motors. I'll run the wires from the esc to the rear motor first and then from there go to the front motor.
Old 08-17-2008, 01:56 PM   #19
sorry for the questions but withthe orings , did you put two per side or just in the outer cups ?
Old 08-17-2008, 03:12 PM   #20
R/C Investor
sgil2001's Avatar
Just one in each outer cup.
