![]() | #41 |
Let's not be Dave.... ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
Well i already killed one of the metal input gears ![]() ![]() ![]() |
![]() | #42 |
Quarry Creeper Join Date: Mar 2009 Location: north central IN
What is all the clicking noise when it starts to turn? Is something binding? Does the axle spin free without the motor installed?
![]() | #43 | |
Rock Stacker Join Date: Mar 2009 Location: Titusville
| ![]() Quote:
http://banebots.com/pc/MOTOR-BRUSH/M5-RS390-12 They rock, but make sure you give 'em at least 8 or nine cells to feed on. They're smooth and controllable, too. | |
![]() | #44 | ||
| ![]() Quote:
![]() | #45 |
Pebble Pounder Join Date: Apr 2007 Location: va beach
have you to to john holmes about your problem?
![]() | #46 |
![]() | #47 | |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| ![]() Quote:
cartronicshn, I have been at that spot for about 3 months now.
Even if these motors work, I will need steel main gears and at least front CVDs to keep it alive. Then will come tires, longer shocks, better links, and better batteries. Not to mention trialling an 9 or 10T pinion from an obscure shop, made out of brass to see if it might, just might hit a sweet spot between speed, contorl and torque and live against the steel spur. This is definetely my "spare time, dink with it" truck. If it doesn't start to pan out soon, the electronics and wheels might get used somewhere else. Done ranting. LOL I'm going to go play with my TLT based crawler now to let the steam off. | |
![]() | #48 | |
| ![]() Quote:
yeah but he might be able to help. it looks like it's bound up in the battery side axle. so it clod stalls, then has you throttle up it jumps forward.. and if there both free rolling and it's simple motor/esc he might have some ideas | |
![]() | #49 | |||
| ![]() Quote:
![]() Quote:
![]() | #50 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
someone explain what stall is?
![]() | #51 |
![]() | #52 |
Rock Crawler ![]() Join Date: Aug 2005 Location: Illinois
| ![]() Quote: Your motors are wired in parallel and not series correct? J |
![]() | #53 |
![]() | #54 |
whens it going to be for sale?
![]() | #55 |
Sorry dude, i hardly ever sell any of my rigs, i will probably just put the stock motors in and have my kid play with it and his losi mrc ![]() |
![]() | #56 |
well my kid didn't like this rig, he rather have my fj 40 cr-01 ![]() ![]() ![]() ![]() ![]() |
![]() | #57 |
Newbie Join Date: May 2009 Location: Everett
i have had my cc for about 6 months now and have done some SERIOUS modding to it. first thing, locked out the rear steer 2nd, scrapped the cruddy rtr electronics 3rd installed a Trx Evx, yes 16.8v got the banebots motors (the rs390s) they are about 1mm longer than the 454s and with 16.8v, a little more torque. so much torque, i snapped the rear axle within minutes of installing my Hotbodies Rover tires {glued :O} (i already ahve all metal gears, and stock pinions, as the banebots motors have the same shaft diameter as the cc5000s (the stockers) the evx also allows VERY smooth throttle, even with almost no throttle, there is no jitter at all, which is amazing because the evx jitters all by itself under the lightest of throttle. more mods: i made bent links for the rear out of 6/32 allthread and 1/4 in brakeline. i also added Traxxas tie rods from my old emaxx (the front ones go up top, and the rear ones go on the bottom, with the stock CC chassis i also added the 4 shocks from my old emaxx with the springs removed result: 90+ degrees of articulation( which i intend on limiting) and 13.5" of wheelbase(yes that just happens to be the same as the NEW emaxx and running in Droop front steering servo is a 2075 atm with the stock, old emaxx servo saver on it, just because i had it lying around and it works well enough. i put the servo link on the inside hole on the steering knuckle and put the connecting link( the one that goes to both knuckles) on the bottom of the knuckles in the outer holes. this achieves full lock steering ( the knuckles touch the axle body now, no need for a longer servo arm or a solid servo arm for that matter.) Batteries: turnigy 2200mah 20c 2s lipos, x2, same size as 2/3a nimh 6-cell packs, with more runtime and 5x the amps and 4x the charge speed (you can charge them at 2c (4.4A) and discharge them at 44A sustained. (if you try that with 2/3 a cells you will be in for a smoky surprise) i attempted to charge a 2/3a 6-cell pack at 4A. it actually blew up (vented) the Turnigy (found at www.hobbycity.com) won't even warm up (no i do not work for Turnigy or Hobbyking) and besides, the lipos are $12 each +shipping, while EP 2/3A packs are $30 each and are inferior in all regards. i also have a 2s novak smartstop LVC, hooked up to the BEC side of the EVX (read: when you hook a battery up with the switch turned on, the steering works, but not the throttle. if you hook it up to the other side, nothing happens at all) to protect the lipos from dangerous overdischarge. i weighted the front wheels with 8 oz total lead strips and solder (yes, solder. al you have to do is wrap it around and then put your foam over and glue/beadlock them on) and nothing in the rear, as the battery is just enough to keep the tires on the ground when it is needed, the truck is over the wheels when it is not. clod stall is not a huge issue, as i can use it as a crude DIG. i am not a comp guy, so i don't care that much about the rules of competition (nor do i actually know what they are, other than some 1.9 rules state you can't have MOA, just shafties) the banebots motors solved this issue with the stock tires, but the new tires made it reappear, but to a slightly lesser degree. Last edited by mattio79; 07-15-2009 at 12:36 AM. Reason: spelling and grammar |
![]() | #58 | |
| ![]() Quote:
