| | #1 |
| Rock Stacker Join Date: Sep 2007 Location: york, SC
| ok im thinking of getting a CC. i now it needs some work out of the box to be a great crawler. what are the best upgrades to make to it first, besides moving the battery and other stuff like that. also ive read about an oring on the dogbone, can someone please show a pic of this so i know the right place to put it. thanks daleo |
| Sponsored Links | |
| | #2 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Out of the box steering is going to be an issue. Adjust the upper or lower links to make sure the front knuckles are parallel to the ground. That will be the biggest/easiest performance upgrade. Are you going with the RTR or the ARTR? Check out my build thread for other ideas: Nluv's Cliff Climber Build & Tech |
| | #3 |
| im going with the rtr because i just have a tq3 and i dont have an extra reciver. also does this truck run off of 7.2 or 14.4v? thanks daleo |
| | #4 |
| Newbie Join Date: Aug 2008 Location: centennial
| it runs off of 14.4-16.8v. also it needs the mini connector on the battery that the vendetta, rc18t, or the hpi micro rs4 uses. all of these connectors are the same but not labeled that they will work. I have 2 Venom 1200mah packs and I get around an hour + out of one run. |
| | #5 |
| RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Deans Micro connectors (avail at your LHS) will plug into the motor connectors on the CC. It is missing the little snap on the connector, but mine have not come loose yet. |
| | #6 |
| Quarry Creeper Join Date: Oct 2008 Location: fullerton
| locking the rear steering and removing the srevo made the biggest difference for me. also swaping the hubs left and right so the small end is down will give u a little more clearence. i have had mine for a week and int went from find the perfect line to try and get it stuck. ive been reading all the threads for this truck and it has helped alot. thanks rccrawler members |
| | #7 |
| Pebble Pounder Join Date: Sep 2008 Location: usa
| glade to here we have helped . ive played alot with this thing an i really like it as well i have 2 of them now . the ccz of dez now belongs to me |
| Thread Tools | |
| Display Modes | |
