Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: getting tires off
Old 10-31-2008, 09:53 AM   #1
Default getting tires off
i no there are a bunch of guys that cant get there tires off the rims here is how to do it.
i heated hy oven to 300 an i put tirs in for 45 min. thay came rite off the rims like nothing . it dint hart the rima at all . durtrax has thken care of us there.
hope this helps everone
randy1
randy1 is offline   Reply With Quote
Old 11-09-2008, 11:39 AM   #2
Default boiling
I tried boiling them off the rims. it will eventually work however it takes a bit of time like 45mins on each tire to loosen the ca. you can still use the tire and rim after the boiling is done. does the baking melt the tire or are the tires still intact to use?
Lestats Ghost is offline   Reply With Quote
Old 11-09-2008, 11:49 AM   #3
no every thig is fine. just be carfull they are hot when the come out
Old 11-09-2008, 02:05 PM   #4
Putting the tires in the freezer immediately after boiling seems to make it go a little quicker for me.
Trike Kid is offline   Reply With Quote
Old 11-13-2008, 11:19 AM   #5
X2 on the freezer.
cory is offline   Reply With Quote
