Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Duratrax bearings & steel gears issue
Old 01-27-2009, 04:48 PM   #1
Default Duratrax bearings & steel gears issue
I bought set of Duratrax bearings and complete set of metal gears.
But when I tried to replace gears and bearings I realized that Idler & Counter gears together with DTX bearings didn't fit back into axle.
The problem is bearings are wider than bushings. I don't want to shave the gears so I will use bushings there. Does anybody has the same issue ?
I'd expect the original parts to fit without problems.
crawlingmike is offline   Reply With Quote
Old 01-28-2009, 07:41 AM   #2
crawling corn
jdawg53's Avatar
When and where did you purchase the bearing set? The bearing company put the wrong bearings in (they were too wide like you mention.) As soon as we found out we had it fixed.
Let me know.
Thanks
J
jdawg53 is offline   Reply With Quote
Old 01-28-2009, 11:31 AM   #3
Bought at TowerHobbies (1/15/2009), but took some time to reach me here in EU.
Old 01-28-2009, 02:02 PM   #4
I had the same prob with mine and I used one bearing and one bushing.
HardcoreTJ is offline   Reply With Quote
Old 01-30-2009, 12:14 PM   #5
gmaxx's Avatar
Same problem here. left the bushings in on that part
gmaxx is offline   Reply With Quote
Old 01-30-2009, 09:33 PM   #6
i boought my bearings one at a time and they didnt have ne that small at my lhs so they stayd bushings nd they havent failed yet
gigercreeper is offline   Reply With Quote
Old 02-11-2009, 08:26 PM   #7
A good friend of mine warned me of this...it's the sole reason I didn't purchase a bearing set for my CC. I'll have to give him a heads-up that there's a fix.
soyverde is offline   Reply With Quote
Old 03-02-2009, 08:51 PM   #8
Has anybody figured out the bearing size problem? I got mine today and they are to big, I thought by now they would have fixed the problem. I got mine from RC Planet. Any advice? I would like to run bearings, that would be the point of ordering a bearing kit. :-(
doubletrouble is offline   Reply With Quote
Old 03-19-2009, 07:07 PM   #9
I emailed Duratrax about the bearing issue and they emailed back saying that they know about the problem, but do not have a fix for the problem yet. They are not sure when they will. Sounds to me like they don't care. It can't be that hard to figure out a solution, they need smaller bearings.:-(
