02-25-2009, 04:13 PM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Ft. Worth
| can I run 3 cell lipo in stock climber?
is it possible to run 3 cell lipo in a cliff climber? I have two 620 11.1 lipos I was wanting to use for batteries and wasnt sure if the climber could handle it? Also if it wont handle the 3 cell can it run 2 cell lipo?
02-25-2009, 04:50 PM | #2 |
nvm found a post saying that the stock esc did not have a lipo cut off
02-26-2009, 11:38 PM | #3 |
Pebble Pounder Join Date: Jan 2009 Location: san marcos
Exactly.
02-27-2009, 08:50 AM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Clymer, NY
You dont need a lipo cutoff to run a lipo. Just keep an eye on it and learn how to read your rig and lipo. I dont have a lipo cutoff on any of my rigs except my crawler running the Sidewinder and never had an issue. I run my CC on a 3s all the time, its not enuff nutt with the stock ESC IMO.
02-28-2009, 12:57 PM | #5 |
Newbie Join Date: Jan 2009 Location: San Anselmo, CA
So, outside of the cutoff issue, will the stock ESC handle a 3S lipo? I think it is rated for 8.4V max input, which is under the 11.1V you would get from 3s.
02-28-2009, 01:27 PM | #6 |
| I would think so. My esc is labeled 14.4-16.8 volt dual motor dual battery esc.....if you ran a single lipo you would actually be below that you could also run 2 1320 2 cell lipos or a single 4 cell lipo
02-28-2009, 09:23 PM | #7 |
You make a Y harness that goes from your Lipo into both plugs on the ESC. Hoing with 2 light weight Lipo 7.4v packs or even one 4s 14.8v wired with a Y harness is better then running 2 inefficent nimh or nicd packs that weigh 3x as much.
02-28-2009, 10:24 PM | #8 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
Or you could just get a dirt cheap LiPo voltage cutoff. Problem averted.
02-28-2009, 10:31 PM | #9 |
02-28-2009, 10:55 PM | #10 |
| http://www3.towerhobbies.com/cgi-bin...?&I=LXPGN1&P=7 You can get them for 2-cell, 3-cell, 4-cell, and so on. It will interupt your throttle and will flash an LED when the LiPo drops too low. Better than blowing up a battery and a rig from guessing. |
02-28-2009, 11:02 PM | #11 | |
02-28-2009, 11:21 PM | #12 |
I'm bit confused on the layout of the stock ESC. Is it just a standard ESC with the inputs and outputs in parallel? If that's the case, running a 3s in series with the inputs will give you 5.55v per output (too low), and running the 3s in parallel will give you 11.1V (too high). Anyone tried this yet? Last edited by mwarner57; 02-28-2009 at 11:30 PM. Reason: wrong info |
03-01-2009, 04:05 AM | #13 | |
03-01-2009, 12:05 PM | #14 |
On mine I plan on shorting the b1 wires out and running a pair of 2 cell 1300 mah batteries run in series. should be plenty of poop for it. I ran it on 1 single 7.2 nimh and it was not enough....it would run but not able to do anything. 14.8 volts should be great and 1300 mah will be plenty of time.
