03-22-2009, 09:56 AM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: Milliken,CO
| Wiring
I just got my mamba max and am wanting to know the best way to wire it? Need to wire it to both motors and would like to still use 2 batteries. Thanks
03-24-2009, 02:12 PM | #2 |
Pebble Pounder Join Date: Jan 2007 Location: Bulgaria, Sofia
I think you need something like that... https://www.tanicpacks.com/product_i...roducts_id=720 And change the males with females and vice-versa for the motor side. Depends what plug's ur using... IDK, are the motors supposed to run on high volts? And is the stock esc made for high voltage? If so, then u need a series style adapter/plug for the battery side, and parallel for the motor side ;) Hope this makes some sense....... Get a friend that is good with electronics, so that you don't mess up (i might have made a mistake sooo... that's why u need someone that knows what he's doing :P) |
03-24-2009, 05:48 PM | #3 |
Thanks for the confidence. I have been busy and have'nt had a chance to mess with it.
03-24-2009, 08:29 PM | #4 |
Rock Stacker Join Date: Mar 2009 Location: Titusville
The mamba max is rated for 12 cells, so wire the batteries in series, and the motors get the full battery voltage (just tested it on mine) so wire the motors in parallel. If you wire the batteries in parallel, you are just increasing the capacity (runtime) and if you wired the motors in series, you would have 14.4 volts across both motors, so if one of them stalled, the other motor would get all the power (the stalled motor would effectively be shorted out) and that could make the clod stall worse. You could also look at it like this: as one motor slows down and gets close to stalling, the lower RPMs cause a lower counter electromotive force, so the ESC sees that motor as effectively having lower resistance, and will therefore get more of the current, reducing the current to the the unstalling motor. This may reduce clod stall. You should definitely wire the batteries in series, and try series and parallel for the motors and see which one works better. I think it will work better with the motors in parallel, but without numbers to plug into equations, there is no way to be sure.
03-24-2009, 09:10 PM | #5 | |
