03-23-2009, 09:57 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: San Diego
| new servo trouble anyone
i was changing out the front servo in my cc and have encountered a problem. the front servo is working backwards, i put every thing back and instead of working like it supposed to all the wheels point the same direction. have ant of you encounter this same problem? any suggestions? ive tried just about everything even flipping the servo and no luck. does the cc come with a servo that operates in revers.:? |
03-23-2009, 10:03 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
You need a servo reverser for it. You can find one at tower hobbies and they aren't that much. I have one for some four wheel steering and they work. All you do is install it and then your servos can work opposite each other.
03-24-2009, 08:01 AM | #3 |
Rock Stacker Join Date: Mar 2009 Location: Titusville
A servo reverser would work, or you can use servos that are opposite rotation on the front and rear. I use a hitec up front, and a Traxxas (or really futaba) on the rear. I'm not sure which other servo brands are opposite rotation, but I'm sure that there are several other combinations that will work.
03-24-2009, 01:42 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
Hitec servos run opposite too, I installed a hitec in the front to get more torque and then flipped the arm in the rear so it points down and made a shorter link to the opposite side of the rear drag link. More torque in the front and got rid of that stupid post in the back. |
