04-11-2009, 08:25 PM | #1 |
Newbie Join Date: Mar 2009 Location: ithaca
| battory ?
ok i just got one cliff climber and i have one on the way.(that are for my boy's 4-6yr). i didn't look to much at the one i got yesterday but i know the battorys have a difront plug then the 7.2's that i run in my ax-10. can i chang the plug on the cc and run 7.2's on them? will it run ok? this way i can use my charger i have and all i will need is some more battorys.
04-11-2009, 09:05 PM | #2 |
| http://www3.towerhobbies.com/cgi-bin...?&I=LXUUR8&P=M is this what i need to use my charger on the duratax battorys? the truck i have has onr battory with it and the truck on the was has 2 if this will work i will only need 1 battory and i will be set. |
04-11-2009, 09:23 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
If the charger you are using has the tamiya plug on it then yes that adapter will fit the CC batteries.
04-11-2009, 09:25 PM | #4 |
04-11-2009, 09:34 PM | #5 |
Yup, the adapter you linked will work with your charger and the CC batteries. Make sure you set your charger for a 1A charger current.
04-12-2009, 05:05 AM | #6 |
cool thank you
