Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: battory ?
Old 04-11-2009, 08:25 PM   #1
Default battory ?
ok i just got one cliff climber and i have one on the way.(that are for my boy's 4-6yr). i didn't look to much at the one i got yesterday but i know the battorys have a difront plug then the 7.2's that i run in my ax-10. can i chang the plug on the cc and run 7.2's on them? will it run ok? this way i can use my charger i have and all i will need is some more battorys.
rladieu3 is offline   Reply With Quote
Old 04-11-2009, 09:05 PM   #2
http://www3.towerhobbies.com/cgi-bin...?&I=LXUUR8&P=M
is this what i need to use my charger on the duratax battorys?
the truck i have has onr battory with it and the truck on the was has 2 if this will work i will only need 1 battory and i will be set.
Old 04-11-2009, 09:23 PM   #3
If the charger you are using has the tamiya plug on it then yes that adapter will fit the CC batteries.
fixed13 is offline   Reply With Quote
Old 04-11-2009, 09:25 PM   #4
http://www3.towerhobbies.com/cgi-bin...?&I=LXRST9&P=M
this is what i have
Old 04-11-2009, 09:34 PM   #5
Yup, the adapter you linked will work with your charger and the CC batteries. Make sure you set your charger for a 1A charger current.
Old 04-12-2009, 05:05 AM   #6
cool thank you
