Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: bead locks
Old 04-05-2009, 09:22 PM   #1
Default bead locks
Hey. Those of you who have bead locks on your CC What kind are you using? i want to get some and some larger tires. What would you guys recomend?
furiousgeorge is offline   Reply With Quote
Old 04-05-2009, 09:34 PM   #2
I always just look around and find what I can get the best deal on. I got a good deal on a set of stock axial beadlocks so thats what I went with.
brokenb4 is offline   Reply With Quote
Old 04-06-2009, 07:57 PM   #3
I am running stock Axial beadlocks. You can usually pick them up cheap in the for sale section.
doubletrouble is offline   Reply With Quote
Old 04-06-2009, 08:19 PM   #4
yeah i found some Axial 2.2 Rockster Rock Crawler Beadlocks at a main hobbies for 21 bucks. im thinking im going to run the losi rock claws on them.
Old 04-06-2009, 08:26 PM   #5
stock Axial bead locks for me with pro-line tires. but you can use any 12mm wheels with any combination of crawler tires
medina619 is offline   Reply With Quote
Old 04-07-2009, 11:24 PM   #6
I also run stock axial beadlocks with pro-line flat irons. Sometime I swap them with the badlands on my scorpion. Whatever tire you use, make sure you put memory foams in them, or get tires with memory foams. They made a huge difference in traction for me.
spartacus_nuc is offline   Reply With Quote
Old 04-07-2009, 11:35 PM   #7
do axial wheels already come with memory foam?
Old 04-08-2009, 06:23 AM   #8
~THE SCALE SHOP~
as mentioned stock axial wheels work great. im running mayhem max width aluminum beadlocks. but they are too heavy for this truck.
STANG KILLA SS is offline   Reply With Quote
Old 04-08-2009, 10:54 AM   #9
No. The Axial Rock Lizard (stock tire for scorpion) comes with regular foam. The tires aren't that great, but they're OK with memory foams. Axial's beadlock wheels, on the other hand, are relatively inexpensive, strong, and very popular.
http://www3.towerhobbies.com/cgi-bin...&I=LXVAH0&P=ML
Old 04-08-2009, 11:04 AM   #10
The wheel you are running is 1.295 wide we have that wheel and a 1.00in. version as well that we just came out with. You can now get all Mayhem Eng. 2.2 wheels 1.295 wide and 1.00 wide. We started production on these last Monday.
To heavy for that wimpy rig of yours....you blame the wheels..........LOL
Thanks Mayhem Eng.
Mayhem Eng. is offline   Reply With Quote
Old 04-08-2009, 12:43 PM   #11
~THE SCALE SHOP~
haha i just came across that, could be the ticket, 1" wide in delrin and one of your lite styles, 7s, or spiders, might be perfect for these little guys. im not kidding dan, i think the wheels litterally double the weight of the entire truck! crawled the best it ever has though! mega stable and more grip, just a bit much for those shitty stock motors.
sorry if i came off as bashing not the intent. wheels are awesome! and i think your new 1" and lighter delrin could be even better! damn you and your marketing genious!
Old 04-08-2009, 01:18 PM   #12
I didn't take it a bashing......It's all good. Pm sent
Old 04-08-2009, 04:11 PM   #13
correct me if im wrong stock axials are 1.9 right? and the axial rocksters are 2.2, i like the rocksters look better, is there any advantages to one over the other?
Old 04-08-2009, 05:48 PM   #14
Stock axials ARE the rockster 2.2" on the AX-10 Scorpion. The biggest advantage to using 2.2" tires and wheels is a little more ground clearance, and you have more different tires to choose from.
Old 04-08-2009, 06:43 PM   #15
~THE SCALE SHOP~
yep the "stock axials", are the stock 2.2 rims that come on the ax-10
Old 04-08-2009, 09:13 PM   #16
Moderator
JatoTheRipper's Avatar
Thanks Mayhem Eng.
How did you go about choosing a width of 1.295?
Old 04-12-2009, 07:47 PM   #17
the axial bead locks and losi claws make a good combo and a stock cc doesnt have any more trouble spinnig them than it does with the stock tiny things
2500hdon37s is offline   Reply With Quote
