04-12-2009, 11:45 AM | #1 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Metal Gears
Who sells the metal gears the cheapest? Can you get a set of the three gears? Do they come in a kit front and rear? Who sells the right bearings? Matt Last edited by SDheavymetal; 04-12-2009 at 08:35 PM. |
04-13-2009, 12:09 AM | #2 |
Rock Stacker Join Date: Apr 2009 Location: ogden
I called DTX last week and asked about the bearings not fitting right they said that the bearing issue had been fixed so thats where I bought mine As far as the gears go they are also on DTX web site and as far as I know they are the only ones selling metal gears for the C.C. and the are sold by the each not by the pair or a full set so you have to buy 2 of every gear to be able to do both axles |
04-13-2009, 12:17 AM | #3 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Towerhobbies sells the metal gears and bearings |
04-13-2009, 12:27 AM | #4 |
Kool are they cheaper price ? I wonder if they are the exact same thing as the DTX stuff with out the DTX label |
04-13-2009, 12:49 AM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: north central IN
04-13-2009, 01:46 PM | #6 |
what about prices the same or cheaper ? my LHS beats ebay prices wich are pretty low to begin with and no shipping to boot ! |
04-13-2009, 01:59 PM | #7 | |
The closest hobby store to me has the same prices as tower does but is an hour away. If it wasn't so far it's always better to support your local hobby shop. | |
04-13-2009, 03:45 PM | #8 |
for sure i heard it put best like this support your LHS or all you will have is junk to sell on ebay !
04-19-2009, 12:52 AM | #9 |
THanks ordered metal gears and motors today. Matt
05-03-2009, 06:34 PM | #10 |
Fogot to order the bearings when I ordered the metal gears-- DONT FORGET LIKE I DID-ORDER THE METAL OUT OUTPUT JOINT ALSO http://www3.towerhobbies.com/cgi-bin...?&I=LXVFJ1&P=Z The plastic output joints broke right away with the banebot motors! Ya I get to pull apart both axles again! |
05-04-2009, 07:51 PM | #11 |
Newbie Join Date: Jan 2009 Location: Houston
has anybody blown a diff gear? my daughter was playing with my CC and ran into something, then the front diff started popping. it still turns the tires, but i can stall the front wheels real easily. what's the weak link here? i don't really have the cash to drop on all metal gears. can i do metal gears and skip the roller bearings?
05-04-2009, 08:29 PM | #12 |
Yes you can install the metal gears without the bearings. I think the noise your hearing is the output joint poping. Make sure you grease the bushings and gears. The bearings make it much smoother. Matt
05-19-2009, 05:56 PM | #13 |
well turns out the center idler gear had a tooth broke off. that and for some reason one of the cross pins in a drive axle walked out and wore a hole in the output joint.
05-19-2009, 10:27 PM | #14 |
| This is why I installed a piece of paper in the outer joint. It pushes the cross pin into the drive axle.
