04-29-2009, 09:12 AM | #1 |
Newbie Join Date: Mar 2009 Location: Rodeo
| Mamba Max ESC, need help on programming!
I just need a little help on programming the Mamba Max. What is the best settings for the CC? Im talking about setting in the computer to set drag brake etc... Parts installed: Banebots Motors (wired in parallel) Tq3 controller 2 packs of (5) 2/3a NiMh batteries each pack..12v total (wired in series) Hitech servo 645mg Thanks!!! Last edited by TheCrow; 04-29-2009 at 09:23 AM. |
04-29-2009, 10:36 PM | #2 |
Rock Stacker Join Date: Mar 2009 Location: Titusville
Sounds like a good setup! I would leave the throttle and brake profiles linear, disable voltage cutoff, set motor type to brushed w/reverse, max out the drag brake and make sure you have the latest firmware.
04-29-2009, 11:36 PM | #3 |
thanks for all your help! without you guys this build is just impossible. I will post some pictures when everything is done. Mamba Max is the way to go!
